OT- Computer Keyboard Cleaning
Ken Oakley-Sunny St. Cloud, Fla
I read someplace a keyboard can be cleaned with soep and water. Has anyone done this and what were the results?
Re: OT- Computer Keyboard Cleaning
Joseph Mulherin, Sr
Ken, just read on Google that you can put into your dishwasher on
HOT water ONLY...no soaps. Also turn off the spin cycle.
type in "cleaning computer keyboards" on Google and up will come the info you seek. Let dry thoroughly for about two days in the sunlight..
Joseph Mulherin, Sr
Do NOT do this on a laptop or notebook keyboards. For those use a canned dry air bottle and spray any dust from around keys, then use a clean soft cloth sprayed with a cleaning solution like Windex and wipe the surfaces of the keys. This should get rid of the messes we all have on our keyboards.
Charles in Mtl.
Ken,
I have cleaned many keyboards with soap and water but I removed the back before doing so. Be careful with the membrane inside though as it does not look strong.
Tried that once...
paul in AZ
I'd read the reports that a dishwasher can clean a keyboard. My one attempt at it was not completely successful. It was cleaner but some of the sticky keys persisted. If the board has sticky, balky keys it is probably worth trying in case it works as long as you don't expect it to work every time.
Years ago it was easy to pop the individual keys off to clean the contacts. Modern boards have a different mechanism and are not as easy to clean manually.
In any case, keyboards are now cheap enough that I regard them as consumable supplies. I get a generic board and not the 'name' brand overpriced sort from Apple every couple or three years.
Re: Dishwasher--I've done this!
Joanne in Point Pleasant, PA
When I owned a computer store, the tech room keyboards would get pretty grungy. I've used Windex or other on a rag and wiped, but I've actually put keyboards in the dishwasher (with soap, even). I put them up top on the rack, keys down. I turn OFF heated dry. When I pull them out, I shake out the excess water and stick them in a sunny spot for a day or so on a towel to dry out. Has worked great for me in the past. As someone else has said--keyboards are pretty cheap to just buy a new one. And it would be nice to have another to use while waiting for the diswasher cleaned unit to dry out.
stacked like...
Tom Dunlap
...cordwood at the thrift store. buying a new one isn't too big a deal. my fav 'boards have a glidepoint built in so i would have to investigate their water proofness.
