OT Stihl Weedeater
OT Stihl Weedeater
OT Stihl Weedeater
Thomas Norton
I have a Stihl weedeater that refuses to prime. I have replaced the priming bulb but it does not suck any fuel up to the carb.
Any thoughts?
Re: OT Stihl Weedeater
John McGaw
Fuel line. Fuel filter. Vacuum leak. Any one or all of these could be the culprit.
Thomas Norton
The filter is good. As for a vac leak I am not sure where to llok. I have had everything apart and the hoses/lines are OK.
Carb re-build kit
My little Mantis tiller just had the same problem and all it took was a little carb re-build kit. YMMV
Re: Carb re-build kit
Thomas Norton
MAybe a little more info will help. When I pump the bulb all it does is make bubbles in the gas tank. There is no suction through the line up to the carb.
John McGaw
This is based on wild surmise so take it FWIW:
If pressing the bulb is causing bubbles it would seem that it is doing the opposite of what it should. Is there a one-way valve in the gas path which keeps fuel (and air) from going down the line to the tank? It seems to me that there should be.
del schisler
sound's like a check valve open and not closing some where Got a diagram ?? Call a repair place and ask them ? Did you take the hose's off ? and put them on backward's ?
Larry in NW OHIO
Del & Tom- That is exactly what I did and very easy to do if the hoses are the same size. After we switched them it ran so much better. Larry
Thomas Norton
I got the carb rebuild kit and she is up and running!!
