You don't need a huge motor on a bandsaw?
wilbur
Tonight I resawed a piece of 8/4 cherry that was just under 9" wide, using a blade that was probably less than optimal: a 1/2" x 6 tpi hook blade. I probably should have used a 3 tpi blade.
Anyway, it went just fine using my 1940's era Walker-Turner 16" bandsaw. The reason I'm posting about this is that my bandsaw still has the original 1/2 HP motor on it. If you read anything about bandsaws today, it seems that serious 14" Delta or Delta clone-style bandsaws have a 3/4 HP motor at the bargain end of the range, and quickly move to a 1 HP motor, and can be gotten with 1-1/2 HP motors. Move up to a 17" bandsaw and you're taking about 2 HP minimum.
I looked at some old machinery catalogs from that era, and it seems that most bandsaws in in the 14-16" size came with a 1/2 HP motor max. I'm sure that they had to resaw boards back in the day as well. So if 1/2 HP was good enough for resawing back then, why was there a motor HP escalation over the years?
Oh, and here's proof that I did it. There's a 12" combination square on the board for scale.
