Bandsaw Blade guide bearing questions
I have a 14" Delta
Band Saw and the lower bearing that supports the blade is shot. Its the one that prevents the blade from being pushed back. Thrust bearing?
Has anyone replaced it? It appears to be pressed onto a shaft that moves for and aft. How do you remove it? Can I buy one at a local bearing shop? I don't want to tear the machine apart until I know I have the replacement. Can a bearing shop tell me what I need? Or do I need to take it with me? I looked it up on the parts site, but they did not give much info. Any help would be appreciated.
Re: Bandsaw Blade guide bearing questions
Jim DeLaney, Austintown, Ohio
Isn't that bearing just held on by an E-clip or a snap ring? It is on mine.
I went thru several bearings - just take your old one to a bearing shop and they'll match it. Should only cost a few bucks for a new one.
Several years ago, I replace both top and bottom bearings on mine with ceramic discs (similar to what Laguna uses). No problems, and no complaints. YMMV
Jim D.
FredD
Now you have a golden opportunity to upgrade your saw, this is well worth considering, I would not hesitate a second.
http://www.thebestthings.com/newtools/carter.htm
Probably a good idea, but I wonder
I have the Carter blade release and the Iturra band rollers and spring and the riser block and home Made dust collection on the saw. I feel like I bought some sort of kit and have spent a fortune upgrading it. I have a credit on Amazon. Wonder if I can find it there?
Re: You sure can
Larry in NW OHIO
Barry Remember to go through WC to where ever you buy your Carter bearings from. Larry
Re: You sure can
I went there and looked at that after I posted. It's $30 more than the the other place. So much for Amazon being cheaper. Oh wait, maybe it's Ebay that's cheaper.
Did have a bit of a hoot when I went to Amazon. My Son's novel came up on the cover page along with an add for the Kindle. At first I was dumbfounded by what appeared to be serendipity. Then I realized it was probably because the last time I went to Amazon I looked up his book and they were just doing targeted advertising.
Hate to use my credit and spend $30 more.
Re: You sure can
Larry in NW OHIO
Sorry Barry, I forgot to add, "If it`s the cheapest". I`m kind of surprized, on the things I bought there, they were the cheapest. :\ :\ Larry
Bearing should be marked....
John in NM
My thrust bearings are 6205's IIRC, and the guide bearings 608's. Both very common. Is the side of the bearing flat to the blade or is it like in the picture in Fred's link? Mine are flat to the blade and wear out quickly - I like the look of the Carter set up better. That said, we installed a Carter set on an Italian saw in a shop I worked for a dozen years ago, and I did not find it to be an improvement. The original guides were hardened plates that spun freely in bronze bushings and worked very well in spite of the plates being expensive consumable parts. Every sealed bearing guide I've used gets sawdust in the bearing long before the race has a groove. Kinda makes you wonder what they mean by "sealed" :D
Re: Bearing should be marked....
I have gone ahead and ordered the Carter guides. Somehow running the bearing in that position makes way more sense to me that running the blade on the side of it. But that's just me. I guess we will see.
The tiny bearings in the band rollers had played out, so I am hoping the larger ones in the Cater guides will hold up better.
