Sort of shop related
Larry in NW OHIO
Sort of shop related. I epoxied a part on my Dust Devil and used the two part epoxy from Walmart. Its the easy in two tubes out the nose and it`s mixed, and you can't use the nose again. I got the inner part of the nose out but now I'd like to be able to clean the material off. What would cut the epoxy off so I can use the nose again? This is a slick way to mix the material but of course you can only use each nose mixing nose once. Larry
Re: Sort of shop related
Jennifer Indy.USA
Larry I've used this same epoxy a lot and if I read your post correctly the problem is that the two exit points for the two part goop got clogged and you can't use it again? I would just cut them off with a utility blade or try a piece of wire to clean them out. That being said...the thing comes with a black cap that fits over both exit points and keeps it from getting gooped up and non useable again. The black cap is one that you have to snap off another part of the unit. it's shaped like a kidney bean.
Jen
Did you use the tubes that are like two syringes side by side and then you mix the puddle yourself or the one that has the long tube that mixes the epoxy internally and it's ready to use when it comes out?
If you used the internal mixing one, can you remove the tube? If so, you may be able to flush it out with alcohol. Denatured alcohol will dissolve a lot of epoxies.
Don't think it will work if the stuff is already set, but it might if you submerge it and let it soak, but I have my doubts.
Heat will also ruin epoxy, but I doubt you can heat plastic tubes enough to destroy the poxy without ruining the tubes.
Of course, the alcohol may cost more than the epoxy.
Larry in NW OHIO
Jennifer no that isn`t the problem. Barry got it part right. I used the epoxy with the tubes on an glued what I wanted to. Now I`m to cheap and want to clean out tubes so as to use it again, if I can. Also I use it right out of the tube and ontp the broken piece. I`m sorry I`m just not to good at discribing things but thanks for taking the time to answer anyway. Larry
Larry in NW OHIO
Thanks Barry, I have them soaking in laquar thinner right now. Thats all I could think of so quick before it starting. But I`ll try the alcohol tomorrow. Larry
Alan in Little Washington (NC)
Until hardened, epoxy can be cleaned up with acetone.
