OT- recessed lighting cans
DouginDenver
I just bought some recessed lighting cans for the first time in a few years, and in the junction boxes are a new style connector I'm not familiar with. They are like a flat plastic rectangle with a separate hole for each wire and you just strip the wire end and shove them in. My only question is once I shove a solid wire in, can I get it back out without ruining the connector - is there some sort of release? The only reason I ask is that I wanted to wire a couple temporarily to get proper placment before installing. I can always use wire nuts or buy new connetors, but I was just wondering if anybody knows.
Re: OT- recessed lighting cans
Larry in NW OHIO
Hi Doug, The push in type wire connectors I`ve run into,you get a small stiff wire and put itt behind the elec. wire and push it in and just pull on the elec. wire and it should just pull out. You didn`t memtion anything about having any screws to put the wire behind, so I assume there are none. But if there are I would use them. Larry
Jay Lombardo
Actually once you put them in it is not worth the effort to get them out and try to push another wire in to the same connector. We typically cut them off and use wire nuts because we usually are using stranded wire, and these connectors don't work well with stranded. I personally am not a fan of ANY kind of push in connection (especially back wired outlets), seen too many failures.
Good Luck,
Jay
steve mackay
I was going to jump in but you jumped on the "stabbing" thing. HATE it. Agree that if it's got screws, for goodness sake, use 'em. I've replaced enough fixtures in this house that were "stabbed" and the wires just fell out BEFORE I even started to work on the fixture.Stabbing is the lazy man's way out. BUT it wouldn't surprise me if EVERYTHING comes with only that option now-a-days. If it had stab only I wouldn't buy it.
