Hot Attic (OT)
Hot Attic (OT)
Hot Attic  (OT)
Larry in NW OHIO
Last year we put on a new steel shingle roof, looks great. At the time they took out the vents and attic fan and put in a roof vent in the peek to let out the heat of the summer. Well I don`t think it`s letting it out very well, especially when it get over 90 out. I`ve been thinking, which can be very dangerous at times, could I put a squirrel cage fan in the peek to help push the air out. I just bought a 465cfm fan for it, but I want to get some suggestions from the WC family first to see if it would not do any harm. I planned to hook it up to the old thermostat from the old roof fan. TIA Larry
Re: Hot Attic (OT)
Re: Hot Attic  (OT) *LINK*
How's your soffit venting? Air has to come in at the bottom to go out at the top. Our attic originally had just a couple of those little eyebrow vents, way undersized for the square footage and no soffit venting at all. When I cut in the soffit vents around the house, attic temp dropped noticeably; and when I added the two turbine vents (not attractive, but they sure function), it dropped again, demonstrating that the top vents were insufficient.
If the area of the top vent's not adequate, you'll need to increase it artificially with some kind of fan, yes. Without more details, it's hard to offer opinions on your squirrel cage idea.
I don't know if it's feasible to insulate the rafter bays in some way to reduce radiant heating from the metal roof. You might also consider a radiant barrier on the attic floor, although I think you're on the right track: bring the attic temp down first.
One of many online resources
Re: Hot Attic (OT)
Re: Hot Attic  (OT)
Bill and his site are correct.
The best ventilation is continuous soffit and ridge vent. If you have a ridge vent, you need to look at eh soffit vents and be sure you have plenty. Either a continuous one on both sides of your house or LOTS of individual vents.
Most of the vents are labeled with their size. What you are going for is NET FREE AREA. You will find that is dramatically less than the physical area. It takes into account the screen and louvers that reduce the air flow. So, you need about twice as many as it would appear.
The advantage of ridge and soffit vents is that it is clearly the most effective ventilation going. If The wind blows from almost any direction it will enter the soffit vents on one side and move up and through the attic and exit on the other side and out the top. If the wind is not blowing, the heat will cause the air in the attic to rise and draw more (cooler) air in through the soffit vents. With Gable vents, the wind has to blow from one way or the other to pass through the attic.
The other thing to keep in mind is that the way heat gets from the roofing down to the house is by radiating off the bottom of the sheathing down. Radiant heat transfer is related the temperature of the radiating surface. It is barely related to the temperature air between the underside of the sheething and the surface of the insulation below. (Think about the Sun, it radiates it's energy to the Earth through 93,000,000 miles of cold empty space.) The Sun can deliver about 1000 BTUs an hour to the surface of the roof. If you have a 1000 SF of roofing, that's a million btus and hour arriving. Typical attic fans can only remove about 25,000 and hour. So, your squire cage may be better, but probably not a lot. If the air movement does not scrub the heat off the bottom of the sheething it will have little effect.
What I would like to try is to install a radiant barrier on the under side of the rafters and see if that would significantly cool the attic. Radiant barriers are somewhat tricky. If you install foil to reflect heat back toward the sheething it will work well for a while. Until it gets dirty. There are foils available that have bubble wrap on them to keep he dirt off the foil. I want to do this to my own house, but I am concerned that the reflected heat might cook my shingles and ruin them. (I am trying to find research on this.) You have a different situation. I doubt the additional heat would bother your steel shingles.
Are your AC ducts in the attic? If so, cooling the attic will help the AC.
Re: Hot Attic (OT)
Soffit vents - what I did
Our house has closed soffits, and the notion of cutting in for continuous venting was a bit much for me. I wound up buying wood-framed foundation vents - some of the yards seem to call them stucco vents - basically a picture frame with hardware cloth stapled in where the picture would be. It was easy enough to cut holes in the soffits the size of the opening and screw the vents in place, using trim-head screws. I made a template, which helped in marking out for the holes. I also pre-painted the vents, and just took a small brush and a yogurt container with about a cup of paint up the ladder, to dab into the screw holes. Worked a treat.
I put in enough vents that the net free area of the soffit venting is about twice the required area. The only remaining problem is that the attic over the back addition, considerably lower than the main attic, still gets hotter than the main attic, because the air gets kind of trapped. Eventually, I may put in a fan to draw air out of that and into the main attic.
Re: Hot Attic (OT)
Re: Hot Attic  (OT)
Larry in NW OHIO
I had some pretty good sized "Hat" vents,I call them, I had 2 with another with the fan in it. I`m going to have to check out the soffit vents, to see if they are clogged or just plugged with dust and dirt tomorrow, if it ever stops raining. What we have are the coragated plastic tile running about 5-8' up the rafters. So I need to check them out to see for sure they are open. Thanks for the ideas. If anymore, I like to hear them. I love this site, Thanks Ellis Larry
Re: Hot Attic (OT)
Re: Soffit vents - what I did
FredD
About Foundation vents.
The vent the yard calls a Stucco vent is exactly that, it has a curled up sheet metal lip that forms a "Key" to receive the Stucco and after the Stucco is applied you have a smooth finished surface .
If the vent is used for stucco the hole for it is cut into the box sill and installed before the Stucco.
If you have wood siding , the vent is turned over to it's other side which is a smooth finished flat metal surface and the vent is nailed over the opening which is cut into the siding.
Rarely is it wood framed though some do , it was a general practice to put twice as many vents at the back of the house , so you could get by with very few in the front which presented a better look.
For myself I prefer Pressed Louver vents which are the same size for soffit venting , you can face the louver so you don't see up into the Soffit, that looks better, the louver vent is a much more substantial vent and not subject to the screen getting damaged , because it hides the screen.
At the bottom end of foundation vents , quality wise , you have a flat metal frame with the screen attached to the back and not much rigidity compared to the combination vent used for Stucco or even less then a pressed Louver.
FredD
Re: Hot Attic (OT)
Yes, but
the net free area of a louvered vent is a lot less than an open one. Different tradeoffs - I lost aesthetic value and gained airflow without having to cut in more vents.
I did have one case where a mismeasurement resulted in part of a rafter tail intruding into the screened area - it was noticeable in the opening; a little flat black paint fixed the problem.
Thanks for the information on stucco vents; I guess the yards that were using that term for the vents to which I'm referring were mis-describing them. It did seem odd to me.
