Have a question? Ask Woody!
Troy Bilt (OT)
Troy Bilt (OT)
Troy Bilt (OT)
Larry in NW OHIO
I have a small roy bilt tiller, 1.6HP. It runs pretty good once I get it running. It starts kind of hard. I have to push the primer bulb and pull the rope, and if it tries to start I have to keep pushing the primer, I guess to push gas into the carb. If I keep doing that for awhile it`ll all of a sudden run pretty well on it`s own. I`m not the best working on these, but sometimes I`ll get lucky. What`s the best course of action here. It`s a two cycle. Thanks to everyone. Larry
Re: Troy Bilt (OT)
Re: Troy Bilt (OT)
Ray - Middletown, IN
My BIL had a similar problem with a Mantis. I found that the very small passageways in the carb had varnish in them restricting the flow which made it hard to start. I ran a very small drill through and the problem was fixed. He had purchased another carb which fixed the problem for a while but that one also varnished over.
Ray
Re: Troy Bilt (OT)
Re: Troy Bilt (OT)
woodenleg
Because of the ethnal(sp) that is put in the gas with the low octane, it is better if you use gas stablizer , one that is design for marine use. That is what all the farmers around here have done. It really helps the gas from getting varnish.
Dave Sorry for the misspelled words.
Re: Troy Bilt (OT)
Re: Troy Bilt (OT)
Just had my lawn mower refurbished. The shop had a sheet laying Ont the counter for All Customers. They strongly and repeatedly recommended Mid grade or high test Gas and Gas Stabilizer. I know nothing about small engines, but that was their recommendation. Also, the gas should be less than 60 days old, preferably less that 30. On advice from someone here I added Seafoam to the gas in mine and poured some into the air cleaner. Seemed to help. Got it at an auto parts way.
Re: Troy Bilt (OT)
Mix SMALL quantities of fuel at a time
Tom Dunlap
Find a large syringe with oz or mm markings on the side and work out the conversion for mixing up quarts of fuel at a time. Having mixed fuel around for more than a month is a quarantee of carb issues. If the mixed fuel is over a month old I dump it into my van when it's low and then fill up the van.
My advice to occasional users of edgers, mowers and others is to get a quality electric unit and drag a cord around. At the end of the tool's life it will have worked more dependably than a gasser.
