Canvas Frame
Canvas Frame
Canvas Frame
Doug Reynolds in Seattle
I've been asked to make a wooden frame for some art on canvas. The canvas would be stretched and fastened to the wooden frame. So, this is not a picture frame but the under-structure supporting the canvas one would paint on. If the canvas' full sixe is 15" X 22", what should be the outside dimensions of the frame, what is a good material to use and how should the joints be fastened? I was thinking of using square 3/4" x 3/4" stock and maybe floating tenons. Is there a better way to go?
Re: Canvas Frame
Re: Canvas Frame
Neal in San Jose
3/4 square sounds light to me. In high school I dated a girl who was a very talented painter. Her father used to make her canvas frames more like 3/4 x 1 1/2 IIRC, and he was picky about his stock. No knots. When he stretched the canvas to get it taut, the sides would tend to pull in, and on some of the larger panels, he even had braces in the middle. He would pull the canvas around the frame and used an air stapler to tack the canvas to the sides.
That part of the operation took 3 hands, so I'd volunteer. I know what you are thinking, and I helped because I was a nice guy, not because I was getting brownie points with the young lady!!!
Re: Canvas Frame
Re: Canvas Frame
Grant Wilkinson
I've made dozens for my wife. I used mostly clear pine, 1.5" x .75". I join them with splined miters. If the size is much over 24 x 30, I mortise in a cross bar on the long side.
Also, I copy the feature that you'll see on commercial stretchers. The outer edge of each piece is a raised bead. This prevents the stretched canvas from touching the stretchers except on that bead. Without this, the canvas touches on the entire width of the stretcher. If the artist paints on this part, the results are different from those on the untouched part of the canvas - not a good thing.
As for size, the canvas should overlap the stretcher on all sides by the width of the stretcher itself. That way, the stretcher pliers can be used properly.
Re: Canvas Frame
Re: Canvas Frame // Bead
AZ in Colorado Springs
Is the bead necessary when framing artwork that is already completed, or is it needed only when stretching blank canvas?
A friend recently asked me to build a new frame for a piece of art work and I was wondering about the bead.
Cheers
AZ
Re: Canvas Frame
Grant Wilkinson
AZ
The original poster was referring to the stretchers (I hope), not the frame. The frame containing the art work does not have the bead that I was talking about. The stretchers do.
Re: Canvas Frame
OK, thanks. I'm sure that's correct. I've never framed canvas artwork, just a lot of photos. Since this e-mail string appeared just when a friend asked me to do this, I took this opportunity to learn something. (I've learned a LOT reading WoodCentral the past year or so!)
Thanks
Re: Canvas Frame
Re: Canvas Frame
Robin Corell in Atascadero CA
Clear straight grained pine is the preferred material and for most size supports 1x2 is sufficient (3/4 x 1 1/2 actual size). There are two ways to build the support one is with the 1x2 oriented so it will stick out from the wall 1 1/2". This is the easiest method because you just rip a 15* bevel on one of the 3/4" thick edges and this edge will become the front. The bevel is to provide a gap behind the canvas. If you orient the 1x2 the other way you will need to apply 1/2 round molding to the edge so the canvas doesn�t sit directly on the face of the support. This is a very important detail because if there is not gap the edge of the support will cause a line to show around the perimeter of the canvas in the same way as if you place a playing card under a piece of paper and make a drawing on the paper.
Splined miters are fine. If you don't what to spline your miters you can reinforce the miter by rabbiting in a 4" square of 1/4 ply on the back of each corner.
Once you go over abbot 36" on any edge you will need to add a cross brace. Cross braces should have a lap joint in the middle but it they do not need to be glued. They should butt to the side supports, no mortise & tennon, no rabbit, no splines. A simple butt joint is preferred.
FYI what you are making is called a support. Stretchers are a seldom needed special type of support where the joints are not glued and once the canvas is applied wedges are inserted in the corners. As the canvas stretches due to humidity the wedges can be adjusted to tighten the canvas. even so many painters will use the two terms to mean a non adjustable frame to mount canvas on.
Re: Canvas Frame
Re: Canvas Frame
Grant: How do I make the bead? I imagine using a beading bit then wasting away the excess to get the bead to stand proud. Robin's suggestion of using 1/2 round sounds easier if I can find any 1/2 round stock.
My friend had a photograph scanned and printed on canvas instead of paper. This is what she wants the supports for. No oil or other paints being applied at this time.
Re: Canvas Frame
Other option
Tony - Memphis
My wife is an artist. I have made a things for her to work on. She likes to stretch her own canvases for some things (expensive smooth canvas), but we buy the frame material at an art store (online usually). This stuff is very inexpensive. It comes already milled with the bead and the lap joints cut. You aren't supposed to glue these because the canvas stretches over time. For some of the things I have made, I used poplar.
Tony
Re: Canvas Frame
Re: Canvas Frame
Grant Wilkinson
Doug: If I were you, I would do what Tony does and buy pre-cut pieces. They are very inexpensive and the set up for doing only one would likely cost you more than the pieces will.
Just FYI, I'm spoiled. I have a free source of clear pine and I do so many that I had knives cut for a shaper. In one pass, they remove the waste and create the bead. I don't know about using 1/2 round. It would certainly work, but I've not seen any small enough around here.
