Little water heater (OT)
Larry in NW OHIO
I`m planing to put a point of use water heater in one of my water lines. I was jusy wondering how the water temp is controled? Is it controled by a thermostat like in the big ones or some other way. Thank you. Larry
Re: Little water heater (OT)
Daves Not Here
If you're talking about a small 6 gal electric point of use heater than yes, it's controlled by a thermostat. If you're referring to an instantaneous water heater than it's demand controlled.
Larry in NW OHIO
Thanks for your quick reply Dav. What do you mean "demand", how does that work. Thank you Larry
Not Dave, but
The on demand heaters do not have a tank, but have a flow sensor that turns on the heating elements when the faucet is opened. Gas versions must be vented but there are electric versions that can be installed under the sink. They require a substantial electric supply. Various sizes are available to accommodate anywhere from one sink to a whole house. The whole house gas versions often have burners that are more powerful than the burner in the furnace that heats the house.
FredD
In addition to Barry's info , the On Demand Water Heaters started being retrofitted in our Remodeling in Ca about the early seventies.
We never used the Electric version , because the whole idea behind them was economical water heating.
The Gas fired version was basically a sheath heater, generally hung on a wall close to a Gas line in the garage.
They give a endless supply of hot water , you eliminate the WH and the continual on and off of the burner to keep the water at the preset temp.
The were developed by the Japanese and at the time we were installing them , they had a lock on the patent.
One caution about them, some older houses with original plumbing won't work well or at all in some cases without the supply lines being replaced which may cost a bunch in addition to a expensive heater.
So a plumber familiar with the operation and installing of them needs to access the condition of existing plumbing , especially G.I. water pipe.
FredD
Different thoughts/questions
Larry, you mentioned "Point of use".
I think of those as the small in line under the sink type heaters that will provide just enough water for one sink. We have also discussed the whole house versions of those above. What are you trying to do? There is a different kind. A very small heater that holds maybe two quarts or a gallon of water and keeps it very hot so you can have a cup of coffee or tea "instantly", or avoid have to heat water on the stove. Is this what you are looking for?
Additionally, if you are looking to eliminate the wait time while the water gets hot you can buy a little circulating pump that has a temperature sensor on it and it circulates hot water from the existing water heater to the sink and keeps it on tap. These used to require a return line, but somebody hit on the idea of using the existing cold water lines as the return. So, you hook this thing up under the sink to both the hot and cold lines and plug it in. Not sure, but I think some of them have timers built in so they only run during certain hours. (I want one of these, because it takes a LONG time for the hot water to get to my kitchen sink and dishwasher and it annoys me to run that much water down the drain. Actually what I would like is to have one with a push button on it so that I could tell it to send up the hot water when I wanted it. I don't like the waste of energy of keeping the hot on hand all the time. I also wonder what effect it would have on the cold water. Would I get warm water out of the cold tap sometimes?)
Re: Different thoughts/questions
Larry in NW OHIO
Barry Sorry I wasn`t very clear as to what I want to do. First off I already have two recirculating pumps. My son has one and I hane one. They work very well for sinksand showers, and we have the one with the timers. just set it for the times of day you are home and usually would be using it, and you do get warm water from the cold side, but it cools down fairly quickly. For me it doesn`t bother me at all. If I were you I would get one if the wait is that long. As for the my situation I have a sink with the cloths washer in the next room and a sink just above it non the second floor. What I plan to do is put the POU water heater under the sink down stairs and tap into the hot water line and that would then run to the sink upstairs and the washer in the next room. The plan is that it would take care of the sink it is under, and the sink upstairs and the washer. It would heat up the water in the water line till the water from the main hot water heater gets to the first sink, so it would only need to heat water in about 30 feet of pipe. I know I`m missing something it can`t be that easy. So tell what I`m missing. Thanks Larry
Why not another recirculator for the sink furthest from the water heater?
Or you could put in a small point of use unit and feed the existing hot water supply into it. It would heat the water standing in the lines and then "top off" the water in the line if necessary.
Larry in NW OHIO
The reason I don`t want to do another pump I was thinking, which is very danderous, that I can heat the water coming out of the main hot water tank much cheaper with the little makeup heater than to turn the main tank high enough where mywife would want it for the clothes washer. She has been bugging me forever and a year the hot water in the clothes washer is not hot enough to get the clothes and bath towels clean. So I came up with this idea. Besides I kind of like to experiment a little and I don`t like the main hot water to be so hot so our little kids get burnt and I`m really cheap. Larry
Look into a point of use heater under the sink. Pipe it into the existing hot line as a booster. And, if you have room, one of those little five or six gallon tank type heaters would work in the same way.
Larry in NW OHIO
Barry That is what I plan on doing, a POU heater under the first sink and on to the other sinks and the clothes washer. If I were you and your wait is long to one of your sinks or showers, I would get one of the Recirculating pumps like I have. I and my son really like them. If you want a little help let me know by email and I`ll be glad to help you any way I can. Larry
Bunn has a coffee maker with hot h20 reservoir
Kneale Brownson..Back enjoying CO snow
Pour some cold water in the top and out comes hot water from the reservoir. No high voltage requirement, can supply a couple quarts of hot water quickly. Recovers fairly quickly also.
