Green PT lumber
Green PT lumber
Green PT lumber
Allen Edwards
I bought some treated lumber to build a picket fence and it's very green. It was almost sticky as I was loading it from the lumber yard. Should I let it age before I build the fence?
I want to paint the fence, too, so any advice on treatment before painting would be welcome.
Re: Green PT lumber
Re: Green PT lumber
John Veerkamp, Western Mo
Allen,
My experience is that you can go ahead and build. There will be warping however.
You will need to wait on painting. Most mfgr's recommend 30 days. It should no longer feel wet before you paint.
John
Re: Green PT lumber
Re: Green PT lumber
Allen Edwards
Thanks for the advice, John. The 1x4s that I'm using for the pickets have already started to warp. I cut them on Monday and some of them are already bent like smiley faces! Will those relax eventually or should I relegate them to the scrap bin?
Re: Green PT lumber
Re: Green PT lumber
del schisler
i build fence with that wood It is the worst wood that you can buy But all i can tell you save the twisted ones and take back Get new one's to replace They will twist even when you get then nailed in place As far as paint Most do the stain I thank paint may be a waist of time You will have to wait tell the wood dry's It is as wet as you can get it You may have to do a primer before paint If it were me i would stain after 30 or so days Depends on the weather sun or lot's of rain ? We bought a pilet of 1x4's and took back 25 or so Sure are junk boards What price 80 cent's now Cant expect much for that price Try and get the one's that have the least knots I know it is like picking out small rocks out of bigs ones ?? good luck
Re: Green PT lumber
Re: Green PT lumber
Allen, when I'm going to use PT lumber I follow several personal rules.
A. Never buy the stuff from the box stores. I only use No. 1 grade, and double KD (kiln-dried after treatment - yes it's out there) if I can get it.
B. I cut the stock to rough length, then stack and sticker it, away from any sunlight in my basement for at least a month with a dehumidifier going. Twisted and cupped goes back to the yard for credit.
C. Before use, each board is "painted" with Floods' Seasonite. This controls the final drying during the 1st year. No other treatment or coating for at least 9 months.
D. After the first year has lapsed, the boards are inspected for feathering or puckering of the grain. Those boards are then sanded to re-level them, and a quality oil-based finish is applied.
Re: Green PT lumber
Re: Green PT lumber
The weak link for treated wood is that it warps. When they treat it, they force water and chemicals into it under pressure (Pressure treated duh.). It is probably wetter than when it was in the tree. Also, the cheap stuff is often reaction/juvenile wood cut out of the center of the tree. Even the warped parts warp. And no, they don't recover. You should buy double what you need and take back the warped half. Or buy a better grade or buy a naturally rot resistant wood and paint that.
It will take more than a month for it to dry enough to paint it. I would be very surprised if you can make a decent coat of paint adhere to it even after it is dry. Check with a paint manufacturer, but don't hold out much hope.
You may be able to find a local yard that sells treated lumber that has been dried after treatment.
Another thing is there are several treatment processes in use, using different chemicals. You need to know Which before you can know how to paint it, If you can.
Re: Green PT lumber
Dale Lenz
Re: Green PT lumber
Dale Lenz
Allen,
I would treat your PT lumber just like "green lumber"
1. Sticker stack it out of the weather or cover with top out doors
2. When lumber is dry to the palm, 2-4(?) wks
3. Work it, the lumber is probably SYP and will need a primer coat prior to top coating.
Enjoy
Re: Green PT lumber
Re: Green PT lumber
Lee Brubaker
I did everything wrong when I built my 6ft.high fencing. I bought PT lumber from a barn store for a reason. Their PT lumber is stressed on the surface & then dipped into a vat of the preservative. Hence, penetation is only about 3/16". I dunno why they call it pressure treated when it obviously aint. Oh well.
In any case after the fence was done, nothing else was done to it.....left in it's natural state. Reason....once you paint a fence you have created maintenance. Down the road it will be needing paint again & I hate painting. If your neighbor decides to paint his side sure as Monday follows Sunday there is gonna be bleed through between the boards to your side, meaning your gonna have to paint again. Anyhow after 18 years, the PT color has faded slightly but other than that the fence is in great shape & just think how many paint jobs that I avoided. Oh yeah....I built the fence entirely on my side of the property line and as neighbors have come & gone a couple of times I merely set them straight on the facts & request that they do not paint my fence, I none of them have. Just lucky I guess.
Lee
