Re: Pressure washer
"fairly inexpensive, not cheap. Something that will do kind of a wide sweep, so it doesn`t take all day to do the deck. I`d prefere electric."
Not possible Larry, as those are mutually exclusionary criteria.
The limit on homeowner-geared 115v electrics are about 1600 PSI. With a wide setting the effective pressure is spread out so you won't be zipping right along. Plus, as with anything else, if you buy for less, you get cheap; cheap gun, cheap build, and, most importantly, cheap pump.
I had a Karcher (bought for the name rep) that lasted 4 years with good care. Service guy offered to rebuild it for $125, I declined, as I had taken very good care of it. I shopped the machines then bought a gas ExCell unit from HD, with 2800 PSI, a Honda GX engine, and a CAT pump. A world of difference! Sure, I'm burning gas rather than electrons, but I have a lot to do, and I can now do the 1,000s.f. deck + 800s.f. paver patio + 150 lineal feet of 4' wide deck-walks in less than a Saturday and have it really clean.
Had a neighbor who lost his job and had to move. Before he left we had them over for dinner. Next day he dropped off a Husky (HD) 1600 electric washer which didn't work well (he said) that he thought I might be able to get running since he didn't want to pitch it but couldn't take. I took it apart, fixed the det reservoir, and replaced the GFCI plug. Does okay for washing the cars and stuff.
