O.T. Round-Up
O.T. Round-Up
O.T. Round-Up
Thomas Norton
Does this product go bad or loss it's potency over time?
Re: O.T. Round-Up
Jesper, Denmark
Re: O.T. Round-Up
Jesper, Denmark
Since it breaks down rather quickly in soil, it may also be water sensitive - from humidity in air.
You can get just as good use from the generic Glyphosate at a much lower price. Farm supply stores are the obvious source.
Re: O.T. Round-Up
Re: O.T. Round-Up
Bill Tindall
Not in my experience. I buy it by the 2.5 gallon at Farmers Coop where it is vastly cheaper and I have kept the concentrate for at least 2 years. A friend gave me some that was 5 years old (again a concentrate) and it works fine.
BTW one gets ripped buying the pre-diluted material. The last 50% concentrate I bought was less than $100 for 2.5 gallons. Liquid detergent bottles are a nice container to dispense from. I have a quart size that I put some concentrate in to be measured out for my smaller sprayer.
Re: O.T. Round-Up
Re: O.T. Round-Up
Joe in a Cleveland suburb
I don't know about the shelf life of this product, but if you have dogs you should be careful with its use. Phenoxy herbicides have been linked to canine cancers.
Phenoxy herbicides are fairly common chemicals used in yard care products. I don't know if the particular product you posted about does, but there are over 1100 names for various herbicides, you can use the link www.alanwood.net/pesticides/ to enter chemical names from the product label to determine if the product is classified as a phenoxy herbicide.
I have Golden Retrievers. Goldens are born with the odds stacked against them. Over 60% die (57% of females and 66% of males) from some form of cancer. Almost double the all-breed average. I do all I can to reduce risk for our dogs.
Sorry to go off topic, but I just wanted to throw that out there. Some people may not be aware of how dangerous some of this stuff is to our best friends. :)
Re: O.T. Round-Up
Round-Up is not a phenoxy herbicide
Bill Tindall
And hence may not be an effective means of eliminating roaming dogs from your yard.
Re: O.T. Round-Up
Jesper, Denmark
Re:  Round-Up is not a phenoxy herbicide
Jesper, Denmark
You do have a way with words, Bill ;)
Re: O.T. Round-Up
Re: O.T. Round-Up
Larry in NW OHIO
Joe IMO you do not go off topic when you give good advice about our pets and furry friends. Larry
Re: O.T. Round-Up
Re: O.T. Round-Up
steve mackay
Every single product of the type I have EVER tried wasn't "potent" when I bought it. Waste of money. (sorry, raw nerve, that one)
Re: O.T. Round-Up
directions for success
Bill Tindall
Buy some 50% active ingredient Round-up or its generic equivalent. Dilute 4 TBS/gallon and spray on almost anything green to wet the leaves. Ward off rain for 4 hours. In 7-14 days what ever used to be green will be brown. It is not effective for clover, but then clover is good and should be encouraged to prosper.
Re: O.T. Round-Up
If you really want to kill vegetation...
Terry Alexander
I have +/- 180 acres of farm land. Fenced. As you all know, if you don't keep growth off of a fence (barbed wire), eventually it will take it down. Also, we have about 1/3 mile of frontage and we do want our place to look good.
Product: Eraser. It "sterilizes" the ground. We spray it under the barbed wire fence and give it a couple of days and whatever was there is dead.....and stays dead for many many months. We only have to spray our fence 2 times a year....maybe 3 if we get a lot of rain (which we usually don't our here in dry West Texas). We also use eraser to kill grass in our gravelled driveway. Wherever we don't want anything to grow, we use eraser.
Caution....it's expensive! But a little goes a long long way. We mix 2 cups to 25 gallons of water (pull behind electric sprayer). Cost $100 for 2 1/2 gallons.
HTH
Terry Alexander in West Texas
Re: O.T. Round-Up
Also
Dan Donaldson
I helps to add a bit of surfactant to it. My FIL buys some kind of a commercial one, but I use a bit of dawn. It helps it to wet the leaves. Round up has worked fine for me. As mentioned, it takes awhile, but the places where I use it are bare ground now.
Re: O.T. Round-Up
Dale Lenz
It is my understanding
Dale Lenz
Round-up has surfactant in it. The difference between Rodeo, water plant herbicide, and Round-up is the surfactant in the Round-up. I've never checked this information out, just what I've been told. I like you Dan, use Dawn dish soap in my 2,4-D and MSMA mixture.
Re: O.T. Round-Up
Make your own.
Ray - Middletown, IN
A couple of years ago while helping the local food bank establish some community gardens we found an alternative to Round Up. The did not want to use any commercial products so a search turned up the following ingredients. agricultural grade vinegar, salt, water, and liquid dish soap. A quick google search would probably find the proportions, I have forgotten what they were. It does work, however, the really strong vinegar smell was enough to turn me off of it. It didn't work quite as fast as the commercial products and some of the really persistent weeds took a couple of back to back applications but it was considered to be the "green" replacement. Not sure I totally agreed with their assessment but it was their party.
Ray
Re: O.T. Round-Up
One More Thing
David Yoho
I had one experience some years ago where I sprayed Round Up to kill some patchy grass in the front yard in preparation for having sod installed, and it did not kill a thing. I found out after reading the directions that it should have been applied after a good watering or rain. I watered the area the next time and applied the Round Up and within days everything died and turned brown.
David
Re: O.T. Round-Up
Dale Lenz
Most herbicides
Dale Lenz
work at making the plant grow themselves to death, so...it's best to hit the plants when they are growing their best. Technically it's best to spray them when they are not flowering or going to seed. When a plant goes into the flowering/seed stage it changes gear, hormonal change, and put most of it�s energy into reproduction. Personal, I�ve never had a problem with Round-up at any stage of plant growth or environmental conditionals.
I use the 41% concentrate Round up and the label calls to mix it at 2%, 2.56 oz/gal. I�ve had good luck with less than 1%, 1 oz/gal. It takes longer to brown out but the sprayed plant seems to quit growing and I get the kill, that�s all I care about.
Re: O.T. Round-Up
Ric Taylor
Re: directions for success
Ric Taylor
I use Round-Up on clover with great success. Clover is a weed in my lawn that I get rid of.
Ric
Re: O.T. Round-Up
I have never understood.......in defense of clover
Bill Tindall
the disdain suburban lawn owners have for clover. I don't consider myself an environmental fanatic, but I do question what some people do to the soil that sustains their lawns. A parcel of grass is not unlike a forest. It is healthy sign if it has a variety of grasses/trees sustained largely without the aid of excessive fertilizer and herbicides. The extension agent, a specialist in grasses by training, identified 7 varieties of grass in my lawns and pastures and declared them the most healthy stand he knew about.
Clover is especially good for dirt and wildlife. A moderate stand of clover in a lawn/pasture pumps out 30 pounds per acre nitrogen that is fully utilized by the pant community growing near it. This nitrogen does not wind up in run off. A great variety of wildlife is aided by clover. Every wild animal eats it as well as many beneficial insects-bees, butter flies, etc. It is among the first nutritious plant to appear in the spring where it becomes an important food source for turkey, deer, quail, etc.
And it's pretty. My lawn is a carpet of white and red clover blooms right now. It escapes me why anyone considers this display of flowers objectionable or inferior to a carpet of uniform green. I do have to be careful to not step on a honey bee.
