String trimmer(OT)
String trimmer(OT)
String trimmer(OT)
Larry in NW OHIO
I have an old strin trimmer that`s been setting around for a couple of years, of course it does not start. I want to start by cleaning the carb. What is a good way to clean it, I would like to keep it on and clean it, but if it`s better to take it off I can do it that way also. I have a couple of lawn mowers I`d like to do it to also, they haven`t been run for a couple of years also. I bought these from a dealer that almost gave them away. They are the same mower I have, if nothing else I can use them for parts. Almost new blades and four very good wheels, at least alot better than what is on mine. TIA Larry in NW Ohio
Re: String trimmer(OT)
Larry, I am the wrong guy to give you advice, (YOUR lawn mower would not start if I just stood near it.), but based on advice gotten here I bought some Seafoam gas treatment/ carburetor cleaner and put a dose of it in the gas tank and a little in the air intake. Got a burst of white "smoke" for about a second and the mower runs better. Got the Seafoam at an auto parts store for a few bucks. (This is my entire experience in cleaning a carb.)
Ray - Middletown, IN
If the string trimmer was stored with fuel you may need to replace the fuel lines and primer bulb. Depending on brand they may deteriorate with age. On the carbs I'm old school and clean with gasoline. I'm sure there are newer and better solvents around now and you might check with the auto supply places. There are places online that sell carb kits for most makes on the market today. Jack's, small engine warehouse, and mowpart are just a few.
Ray
Seafoam does a great job
Dustmaker Mike
I would start with the Seafoam and see how that work. I have had success a few times with it. If this does not take out then gum I would check the primer fuel lines etc until I had the carb in my hands. Then I would clean the carb with Seafoam and reassemble.
Have Fun
Re: String trimmer WON'T Start----?
Dave (PacNW)
After 15 years in Chainsaw/ small engine repair, I found that the first step when trouble shooting is to put in a NEW SPARK PLUG!!!!!! 98% of "Carburetor problems" are the ignition and Spark Plugs 70% of the 98%. The next step is ,put in a new fuel filter and Fresh Gas. Then to rebuild the Carb, New Diaphragm and needle and seat etc. If it still won't start, the trouble shooting can get involved.
Good Luck,
Dave (PacNW)
