We value your privacy.
I have a bunch of pin oaks on our lot and on them in the spring most of them grow a bunch of little sprots on them, I assume they are limbs starting to grow out. Now if a person wants to keep limbs, if that is what they really are, from growing are you suppose to take them off. A couple of questions, are they really limbs starting to grow out andf if you let them alone will they all grow into bigger limbs, and if you take them all off will it hurt the tree any? Larry
We have a LOT of oaks on our 180 acre farm frontage. Yep...those "would" eventually grow into full limbs. However, we think it makes the trees look "scruffy" (kind of like a guy with a 3 day beard growth...all over his body). We just finished trimming all of those off as high as we can reach from the ground. Then, one of us gets in the back of the pick up and we trim as high as we can reach there. We use a Dewalt battery powered reciprocating saw. Doesn't take anytime to trim them up. Takes longer to pick up the trimmings than it did to trim them. Trees (and associated frontage) then look "pretty"...and that's very important to SWMBO!
That`s pretty much what I thought, just wanted to verify it. I do the same thing, trim them off as high as I can reach with my ladder and with using a bush knife. It seems about cutting some hair, except on my head, the more you cut them off the more grows out. Larry
If you want to spend the money, go to your nearest full service nursery and look for a spray bottle of stuff that's supposed to keep pruned trees from re-sprouting at the pruned spot, kinda pricey though. I don't recall the name of it. It's for fruit trees but you can ask them if it would work for oak.
Pin oaks love to hang onto all their branches. In deep woods the lower branches just die and stay on the tree, and and the tree grows around them, making for poor knotty lumber.
Be careful of thinking biologically when botanical thinking is correct.
Sprouts come from limbs and the trunk, suckers from the roots.
Woody plants don't grow 'extra' leaves, they grow as much as they can. When stimulated they may build a food factory to make extra food which is the starches that becomes wood. The more food factories a tree grows the more fiber it can store. Trees won't grow themselves to death either. If the starches are available growth will happen.
Skinning sprouts off of the main trunk isn't a bad thing though. Many years ago I picked up an old book written about fruit orchard tree care. The author shared a tip that I have followed since then with great results. If sprouts or suckers are cut off at the branch collar latent bud cells will be left in place. The tree will generally resprout since the cells are packed around all branch collars and to a certain extent in the internodal areas. These are waht you're seeing on the trunk. His suggestion is to wait until the sprouts have JUST hardened off and gotten woody. Then, carefully tear off the sprouts. This will leave a ragged hole but it tears out the branch collar and the latent bud cells at the same time. You're much less likely to have more sprouting in the future.
After reading about this ripping rather than cutting I did several experiments at clients properties where I returned every year to prune their trees and shrubs. On several trees I would take certain limbs or portions of trunks and rip or cut the sprouts. Sometimes I would rip one side of the trunk and prune the other. The next year I saw a HUGE reduction in sprouting on the torn out sprouts. Enough to convince me to make the change.
Now, I'm that arborist at a small univeristy campus so I get to experiment and see the results on a daily and weekly basis. It works!
Timing is critical though. Once the sprouts harden off and get woody you're less likely to be able to tear them out without making long nasty tears. In that case make proper branch collar cuts.
Sprouts can be nurtured into branches too. If there are bare spots with lots of sprouts pick some out that have good attachment angles and growth aspects. Then, cut off the rest. YOu'll change the growth of the tree.
If you want to learn more about trees and tree care see this site.
