ADVERTISE HERE - FREE TRIAL
Filling screw hole for hinges
Dave
Dave
Item is a mahogany butler's tray coffee table with four hinged leaves. Screw holes are severely enlarged. What is the best method for filling these. I know the toothpick/glue method but suspect this won't be good enough.
Re: Filling screw hole for hinges
I make plugs...
John in NM
just like the toothpick thing but bigger. I usually just split them off a scrap of wood with a sharp chisel and shave to fit, a bit on the tight side, then glue them in and re-drill.
Re: I make plugs...
Doug Reynolds
I've done the same thing recently with European hinges but, wonder if there are potential problems lurking as I am setting the screws into end grain.
Re: I make plugs...
I have not done it on furniture, But I did a whole house full of doors where the hinge screws had been wallowed out. I used a plug cutter and cut a bunch of plugs that fit in a 3/8" holes. Drilled out the holes, glued in the plugs with Titebond and trimmed the flat with a sharp chisel. Then reinstalled the hinges. Worked great. Also did the same thing on the screws for the latches. No problems with either.
By making your own plugs like this, you are not screwing into end grain.
DizD
LV makes a tapered hole cutter that matches angle of a pencil sharpener. Ream out hole with cutter, then take stock the size of a pencil, sharpen the end, cut off tapered end and glue into hole. Works well for me for box hinge repair.
Fast method for filling screw hole for hinges
Lee Schierer McKean, PA
I keep a selection of various sized dowels on hand (1/8"-1/2"). I sharpen one end of the appropriate sized dowel in a pencil sharpener, coat the sharpened end with glue, tap it into the hole and cut it off with a flush cutting saw. If the dowel is too long, I sometimes cut off the pointed end a little longer than needed and then tap it into the hole with a hammer.
I've worried about the same thing,
and have, like Barry, made side-grain plugs at times.
But, for small holes, I think the toothpick or equivalent works a little differently from screwing into monolithic end grain. If you fill a side-grain hole with a stick of end-grain wood and install a screw, I think the end-grain wood winds up serving more as an expansion plug, pressing against the side-grain sides of the hole. This would not necessarily apply to larger holes, or holes that were so thoroughly blown out that the screw won't even begin to "take" without a plug.
This is, you understand, all wildly speculative, not based on hard data.
Re: Fast method for filling screw hole for hinges
FredD
The end grain of a dowel works best, as it can expand into the hole if the hole is predrilled to accommodate dowel size , use glue , then a pilot hole for the screw and you home.
FredD
Tapered plugs
Tom Dunlap
Many years ago I pruned some trees for a client. When I was done and we were squaring up for the job he showed me a tool that he had invented. It had a screw driver handle with a tapered reamer on the end. then he had some tapered plugs to match.
He is the guy who invented the tool and he was just beginning to market it. that is a clever solution...one of those head-slappers in its simplicity.
Lee Gordon
Lee Gordon
Golf tees.
Larry in NW Ohio
Lee, you must have a lot bigger pencil sharpener than I have to sharpen a 1/2" dowel. Larry
