We value your privacy.
Late last night, my Campbell Hausfield hotdog struggled, while running, then slowly quit. As the motor stopped, air pressure leaked or vented; I couldn't be sure whether from the relief valve or from the gauge that's just above the relief valve.
Couldn't get the motor to start back. It's an oil-less compressor that appears integral with the motor.
It's 13 years old, about. I'd bought it as a refurb, and don't have any manual or instructions.
i doubt that you will fix it cheep Most likey the piston or rod is bad it has rings on the piston which probly gave out then seazed up Take it apart and see what is bad if the piston comes out real easy and the Cylinder Wall no mark's their and the rod end cap not broken that maybe a new piston with rings could fix it the air leak probly came back thro the piston to crank case Look parts up and desige It is nat a hard job to fix Have done lot's of them You got good service out of your's or yr's Most are not used that much That is the type that i wouldn't buy myself I use comp. every day The only kind to buy it the external comp. and motor Of course more money But in the long run if you use comp every day That is the only way to go good luck
Go compressor shopping. You got good service from a machine designed to self-destruct. Moving metal parts deserve oil if they are to last any length of time. Sometimes it is cheaper to move on.
I bought a used compressor from a guy that just had to have an oil-less model. That was twenty years ago. I did replace the reeds 6 years ago, but it still runs like a champ. After the new shop is built, I will run down and fix the leaks that have occurred since moving to Arizona.
