OT sorta, Tile Wet Saw *LINK*
Tim Greif - West of Chicago
LOML has decided that the 20 year old tile in the shower and whirlpool tub area are dated and need to be replaced. I'm of the opinion that they look and work just fine, but I've long ago given up on trying to reason with females on issues related to interior design or looks.
I went to purchase an inexpensive 7" wet saw for tile work at the local HF store. Got the saw home and discovered that it says "blade sold separately". My fault for not noticing that. But the engineer in me says I just bought a motor, not a saw. How can you call it a saw if has no blade. I digress. Just had to rant.
Has anyone used this saw? Or one similar? It's $59, but goes on sale thursday for $49, plus the $20 cost of the blade, which is a bit non-standard since it has a 1" arbor, not the normal 5/8". I will consider this a one project purchase since it's probably less than renting one to get the job done. I have a bunch of cuts to make, so I may very well wear this one out. If it dies during the project, I'll return it under warranty. Please don't tell me to get a Felker. I'm not going into the tile business. I've never done one bit of tile work before.
Any advice here will be greatly appreciated.
HF Tile Saw
Re: OT sorta, Tile Wet Saw *LINK*
Jim DeLaney, Austintown, Ohio
Yeah, I have that same saw, but mine came with the blade. I've had it for about six years, BTW.
It works very well. Cuts cleanly, but the tilting table takes a tad of getting used to - although you'll probably not need that feature often.
One (minor) drawback: it's cooled/lubricated via the blade sluicing through the pan of water under the saw. Therefore it throws water everywhere, and particularly to the front, onto you, the sawyer. Use it outside, and well away from any fence, wall, or other feature you don't want to see a spray streak on.
Jim D.
John E in SC
Another thought - I rented a wet saw once, and it made such a huge mess, I decided to try another approach. I've since then done probably a half-dozen tile jobs using a cheapy "score and snap" tile cutter for straight cuts (no dust, and MUCH quicker than a saw), and for irregular shapes, used a Rotozip with a diamond circular saw blade (dry). It makes a lot of dust, but I used it outside, and the dry dust was easier to deal with than nasty water sprayed all over you and everything else. Just my 2 cents.
Scott Greaves in Blackfoot ID
Hi Tim,
My cheap tile saw was from Home Depot. Probably the same saw. I've had mine for years, and consider it a valuable purchase. Good advice about it spraying water. Just wear an old shirt and some safety glasses!
Scott.
Home Depot
Dustmaker Mike
I bought the work horse from the HD a few years ago. It does a great job if I remember correctly it was only about $89 total.
Hamish
Hi Tim,
I have both the wet saw and a "score and snap" tile cutter that I used to re-do our bathroom. They both work well but If you find yourself cutting 90� "bites" out of a tile to fit say around a corner, or something similar, the wet saw is the tool to use. To minimise the amount of water thrown in your direction while cutting, I kept the blade cover as low as possible and I wore a piece of plastic, like an apron, to stop myself getting too wet.
While doing our bathroom, I had to make a lot of 45� cuts using the wet saw, so rather than trying to follow a line freehand, that usually got washed away by the spray from the blade, I cut the angle out of a thin board, inserted the tile and ran it through against the fence. This worked very well. Sometimes as I neared the end of a cut, the tile cracked and left an uneven edge. To get around this problem, I first cut the end of the cut for about 1/2" then turned the tile around and proceeded from the beginning. It seemed to solve the problem.
Good luck, Hamish.
Jim Dillon
Tim,
I have no experience with that tile saw, but 6-7 years ago I bought the $89 Plasplug (or something like that) tile saw from the local borg. I expected it to last for one bathroom tile job but that thing has been a real workhorse. So far I have done the bath, kitchen and a 400 square foot living room floor set on the diagonal so I ended up cutting roughly 50 12 x 12 tiles on the diagonal for the edges against the wall. I originally bought a second blade as I never expected the one that came with the saw to last, but it is still going strong. It is not fast, and throws a lot of water at you, so it is a messy job best to do outdoors. And, as other poster have said, be sure to wear safety glasses as pieces of tile can get thrown at you. Ended up being one of my best buys.
Jim
Clint Searl
Get a Felker
Clint Searl
Larry in NW Ohio
My son bought the basic same saw from a borg, I don`t know which. For the cost it works very well. For a water splatter cover, we make it out of a garbage bag with holes for the arms and one for the head. For cutting curves and such things, I bought a 4" cement blade for on my hand grinder. Cuts just as fast dry. Good luck. Our shower was 30 years and it was good as new, but for some reason must do what the wife asks for, sometimes. Larry
Justin Szeliga
I found this
Felker FTS-50 Portable Tile Saw
if you google it you'll find a Felker for under $100.00.
I bought a Plasplug saw like Jim 10 years ago, used it on alot of repair jobs & 1 full bath, bought a Felker TM-75 that got stolen, then bought a 10" 1hp Felker when the next big job came along. I still use the Plasplug for small jobs & repairs, it just won't die. No matter how hard I try. It is still cutting. One of those cheap pieces of stuff that lasts so much longer than I ever expected it to.
I think you should return the HF saw because I think they are such cheap products that noone should ever buy them. I got the willies when I walked through the store, never to return for any reason. Also, selling a wetsaw w/o a blade is just lame.
Peace
Justin
Steven Antonucci
Other uses for my tile saw
steven antonucci
I bought the cheap HD version (yellow, forget who puts their name on it) and it has served me very well for the years that I have owned it through a couple of tile projects. certainly beats renting a " good one"...
I have used it to cut geodes in half too. I don't think a new blade was $20, but it's been a long time since I bought one...
S
Thanks guys.  HF saw is going back.
Just got another surprise from LOML. the stuff we are going to install is porcelain, not ceramic. I'm told porcelain needs a bit higher quality blade since the material is harder. An I have no way of knowing anthing about the HF blades. So it looks like I'll pop for a bit more expensive saw from one of the borgs and perhaps an upgraded blade. LOML is worth it, right?
Believe it or not, she wants this saw for Mother's Day. Is this a great country or what? Life is good.
Re: Thanks guys.  HF saw is going back.
Joseph Mulherin, Sr
2 1/2 years ago I laid 350 porcelan tiles in our house. Tried the score and break cutter, but it left cuts I could not stand, so took it back to Lowes and bought the small electric wet saw they had...cost about $70 I believe. Measured all my cuts and labled each tile, made many cuts and then installed them in their labled spaces; Setup saw on my portable Workmate and wore an apron while cutting. Still have the saw and it still works fine.
After that job, I repainted the entire inside of the house, ceilings included, and then went outside and repainted the entire outside....all this within 6 weeks or so working only a few hrs a day. SHMBO is really satisfied....
