Jet Dust Collector noise
Paul Blackwell
I have a Jet 3 hp. canister type dust collector, and yesterday afternoon after a full day of use, I started it and it let out a horrible screech like metal on metal. I quickly shut it down, and figured that the nut on the motor shaft had loosened up as it had once in the past. When I assembled it that time, I used Loctite on the threads. Today I removed the cover, and could find nothing wrong. The impeller spins freely, no play anywhere. I started it with the cover off, and it didn't make any noise, so I cleaned the canisters and put it all back together. I tried it a couple of times, and it was okay. I went to use it again, and again with the screeching noise. I removed the cover again, and the noise happens most of the time, but not always. Do I have bearing problems with the motor? If I hear the noise on start-up and don't shut it off, the noise stops when the fan gets up to speed. These thing are so simple that not much can go wrong. It's either the fan or the motor. Any thoughts??
Re: Jet Dust Collector noise
Check your keyway. sounds like you lost the little key and the impeller is spinning on the motor shaft until the friction gets it up to speed. BTDT
Larry in NW Ohio
Paul As you said, not much to these machines. When you had the cover off did you look around inside that something isn`nt rubbing, maybe in back of the impeller or the front of it, inside of the housing. If nothing inside rubbing the impeller, very small chance would the housing rubbing the motor shaft. The only thing left is inside the motor. Probably can`t really tell on startup where the noise is coming from. Can you take things off one at a time, like the cover and start it and see if it makes the noise. Then the impeller, start it is it still there, and so on, untill you find it. Be very carefull. Best of luck. Larry
Andy Wright
I can only think of three "likely" possibilities
1) impeller is rubbing something in the housing (sounds like you eliminated that)
2) Impeller is slipping on the shaft ofthe motor. Remove the impeller. If there is wear on the motor shaft then this is probably your problem.
3) The motor has a problem. It may be bearings in the motor. If this is the problem I would recommend finding someone in your area who services motors and have them repair it. A 3HP motor costs several hundred dollars so it is worth repairing
Good Luck
Paul Blackwell
Thanks for all the advice. I carefully checked that the impeller is not rubbing anything. The impeller is not loose on the shaft, and there is nothing in the housing to interfere. If you slowly turn the impeller, there is a kind of squeek which must be coming from the motor, bearings I suppose. I can't detect any feeling of roughness when the impeller is slowly rotated. I reassembled everything, and used the dust collector several times this afternoon, and it did not make the noise even once. Guess I'll just wait for the noise to reoccur and take the motor to be checked out.
