Cyclone Dust Collector exhaust question
Andy Wright - Allen, TX
I recently bought a PSI cyclone used and installed it in my shop, and have a question
My question is regarding the exhaust and filter. I have a muffler which came with the cyclone which I want to use, plus I would like to get the filter off the floor of my shop. CAN I MOUNT THE FILTER HORIZONTALLY? I was thinking of mounting both the filter and muffler on the wall as shown in the diagram. I have seen other installations where the cartridge filter was horizontal, but wanted to get a few opinions and see if anyone has had problems with that setup?The benefit is that it would free up space in my shop, and allow me to reduce noise by using the muffler.
I will also proactively address the comment that I know I am going to get: I know the 4" dusctwork is undersized, and I plan to upgrade to 6" in the future. The 4" PVC was already in place from my old DC, and so for the short term I just made a simple modification of the inlet location to make it work with the cyclone.
Re: Cyclone Dust Collector exhaust question
I wouldn't do it that way. IMO, the dust is supposed to fall to the bottom of the filter (in the little metal tray). If the filter were horizontal - it would fall in the lower surface of the filter and be a PITA to get out.
I usually check my filter and the bottom tray about every 3rd drum. I find very little dust, but I do find some.
Larry in NW Ohio
I agree with JL, I would go with the flow of nature. Everything will want to drop down, it probably will not be enough to cause problems very quick but in time it just might. IMHO Larry
Matt Overton
I have the same unit and reviewed the installation with Jeff at PSI (he is a friend and I am local). The method of cleaning the filter is to blow out the dust with compressed air and let the dust fall into the small canister and vacuum it out from there. I actually installed mine in the attic of my shop and chose to cut a hole in the ceiling through which I put both the large canister and the bottom of the filter. All that takes up space in the shop are the two canisters. I guess you could put it horizontally, and dismantle the filter periodically to blow it out, but that would be a PITA. Give Jeff at PSI/ MLCS a call for his opinion, He has installed tons of these systems and is a great guy.
Grant in Iowa
Andy,
I'd try to reconfigure the setup so you are minimizing bends. From the photo, you might be able to raise the unit enough to place the muffler and filter in a straight line (or very closely) above the garage door.
You might also be able to to rotate the blower assembly in order to allow placement on the left wall.
Just know that the fewer bends you include in the setup, the better it will perform.
FWIW,
Grant in Iowa<---needs to get on the ball and order up some DC ducting himself
Wood Magazine plan
The main reason why I am asking is since the old plan from Wood magazine had the cyclone with a filter mounted horizontally between the basement rafters.
I guess the common wisdom among everyone here is that vertical is better
Jim Rahbe, Bedford Texas
No Problems with mine..
Andy,
My homemade filter (a Truck Air Cleaner) has always been mounted horizontally, and I�ve never had a problem. A couple of times a year I take it outside and blow compressed air through it. In my case, the dirty air enters from the outside and comes out the hole at the end. I doubt that makes much difference in cleaning it.
The gray flex pipe, on top of the green PVC pipe, is just a scrap piece, not connected to anything. Did not even remember it being there...
Jim R.
Solution
After reading comments and doing some additional research, I decided against mounting my filter on the wall horizontally, and went back to my original goal: getting the muffler installed on the cyclone to reduce the noise level. There are usually multiple ways to solve any problem, and so I started looking at other ways to make the filter+muffler to fit under my 8' garage door. In the end I replaced the cardboard drum cleanout with a custom built box which shaved several inches off of the total height of the filter stack. Those inches were all I needed - now I can open my garage door without any interference
In the pic below you can see the difference between the original drum and the "custom" clean-out I built today.
Question.....
Does the muffler work? Just curious. I don't have a cyclone and my DC unit is outside my shop, but does the muffler help?
I'm sure you don't need me to tell you, but it might be better if you raised the cyclone a foot or more to eliminate some of the bends in the piping on both sides. I know you are planing to upsize the pipe, now is the time to move the unit. I have already moved mine and may move it again.
Re: Question.....
The muffler did queit the cyclone down quite a bit.
I am going to move the cyclone up as high as I can without going above the garage door track. I think that I should be able to cut the flex hose down to a minimum amount which should help make the DC more efficient and also keep the noise level to a minimum.
