Time to Dump the Combination Blade?
Steve in Phoenix
I've gotten alot of use out of my Freud thin kerf combination blade. And I'm looking into purchasing a couple of full kerf blades. My only concern about a rip-only blade is how the edge of the wood turns out. Does it end up needing more work than using a combination blade?
Re: Time to Dump the Combination Blade?
Why
Bill Tindall
I can't imagine why you would not keep a combination blade on your saw for routine work. I keep a 7 1/2" 40 tooth very thin kerf on my saw and it does most of what I need it to, more safely. I change to a specialty blade as needed.
There are two kinds of rip blades- "glue joint" and production. A production rip has a few big teeth and it rips thick stock effortlessly but the cut is rough. A glue joint rip produces a smooth cut, requiring more HP from the saw and a slower feed. I have and use both as needed.
Re: Why
Steve in Phoenix
I am thinking along the lines of having blades singular in purpose to do their jobs very well. I could be wrong, I've just never had a ripping blade before. When I rip, I rip alot. And I don't mind changing blades.
I think my combo blade has seen plenty of action at this point. I kind of "learned" on this blade, if you get my drift...
I agree, and there are safety issues here too
If you're going to be doing a lot of ripping, especially in thicker stock, you should be using a full thickness ripping blade. There are several good reasons. One is that a thin-kerf blade will overheat in prolonged heavy ripping and you can end up with a potato chip. Another is that a combination grind is a compromise between efficient ripping and smooth crosscutting, not a dedicated ripping tool. The geometry of the combination grind usually features lower side relief and a less aggressive rake -- not to mention too many teeth (40 - 50 on a 10" combination blade as opposed to 24 or so on a similar diameter ripping blade) -- which result in more teeth in the wood at a time, greater feed resistance and more of a tendency to overheat in repetitious ripping. If the blade gets too hot, it can start leaving burn marks and even become a safety issue as the metal expansion defeats the tension ring that they roll into blades to make them perform properly and run flat at normal operating rpms. A blade that starts to wobble is an accident waiting to happen, or about to happen.
Re: I agree, and there are safety issues here too
Steve in Phoenix
Should I plan on ripping a touch wide to run both edges along the jointer to smooth them out? Or is there a specific tooth style/angle I should be looking for in order to keep the edges smooth?
The place I bring my jointer knives to be sharpened has a house brand (German import with his company logo on it) that had competitive prices. And (as he found important) plenty of carbide to allow for lots of sharpenings. Does it really matter if I go with a name brand?
Thanks
Worth a try
When I ran a professional cabinet shop, I used to buy blades and router bits and shaper cutters from a distributor who only dealt with businesses. Often the tools were made to order for a job, but they were put together by manufacturers who never surfaced in the retail market. It sounds like your distributor may be in that league. There's no way for me to predict how well his blades may perform, but ripping is a rough step in the breakdown process, so you don't want to be too fussy about it (unless you're running a tractor feed rip saw with a glue-line blade, in which case, you want to saw to dimension and have clean ripped edges ready for gluing).
The fact that your guy is talking about the size of the tips and multiple sharpenings is a good sign that he/they understand the importance of proper sharpening to remove the least material necessary, and that their blades are optimized for it, with larger teeth. Engineers at Freud in Italy told me the same things, so you're in good company.
All you can do is try one out and see how it works for you. Generous carbide, in an otherwise well-made blade, is a big plus that can pay off handsomely in blade life.
Regarding dimensioning your stock when ripping, especially for furniture, millwork and cabinets: as I said, this is generally a rough operation where saw marks are expected so you shouldn't consider the cut edges to be the final surfaces ready for glue. If you're only ripping a couple boards and you want to have usable glue-line edges from retail blades, here's where a combination blade might be the right choice. It's just not the best blade for ripping 300 LF of 3" material, or even a couple hundred board feet of cabinet stock.
Depending on the wood and how it was going to end up in a piece, I'd always cut oversize and figure on jointing and planing to finish size later, after the rough rips had equalized in orderly stacks under weights (sash weights and chunks of I-beam were the usual suspects) for a week or so. This process gives the wood a chance to warp and bow a bit, and it's a reason to make extras of everything, so you can toss or repurpose the clinkers.
Re: Worth a try
Steve in Phoenix
Thanks for the advice on the blades. I'll pick up a rip and crosscut when I stop by monday (American Saw & Tool in Phoenix).
I learned a real fast lesson on rough ripping with African Mahogany. I ran a few 8" boards through the jointer and planer, then ripped to width. Not a good idea. I rough ripped, and ripped to final later. Fussy wood...
I have been considering rough ripping boards on the bandsaw. Perhaps it would save on setup time with boards all differing in width. No feather board to mess with, just push em on through. Less loss from those full kerf carbide blades...
Re: Worth a try
Robin Corell in Atascadero CA
to a great extent the your blade choice should be influenced by your saw. The intitial reason for thin kerf blades was not to save material but to reduce the strain on the motor.Or to put it another way it is a way to be able to cut thicker material with less power. The compromise is generaly a lower quality surface and less acuracy due to blade flex.
with that in mind I would recomend going to a .150" kerf 24 tooth blade for ripping. You wil be amazed by the quality of the cut.
Robin
Moses Yoder
Re: Ripping extra wide
Moses Yoder
I generally set up my jointer to take off exactly 1/32" and then rip stock 1/16" wider than the finished size. After jointing both edges it is now exact size. I normally take a few passes with a smooth plane on the edges but am not concerned about the few thousandths that this takes off the width of the board.
Ripping on the bandsaw
Frank Klausz is a firm believer in ripping anything 2" or thicker on the bandsaw. I tend to agree, although I don't have an outfeed table on my bandsaw, so longer pieces are a pain to rip unless I have a roller stand set up or a helper to take the outfeed. When we were building driveway gates, we'd routinely rip 3" or even 4" mahogany on the tablesaw. The 4" stock required two passes from opposite sides of the board with our 10" saw. You need to be a bit more careful when ripping rough lumber, as sometimes it isn't uniform or straight or flat, so those cuts can be squirrelly.
That works *if*...
... your lumber is thoroughly equalized and stable. Otherwise, you end up with a slight bow or twist after your rip cut, and you need to lose dimension in order to flatten things out again. If the board is perfect off the tablesaw, a thickness planer is a better machine for reducing it to thickness, as you're more likely to maintain parallel surfaces.
Ditto
The only stock that I rip to final dimensions is plywood and MDF/composits. Even with wood I'm confident is stable, I rough-rip using a rip blade then face-joint. I let it sit overnight and check the faced surface for straightness, if ok, I then plane to thickness. The last operations are to joint one edge straight and use that for the final rip. I use a Systematic glue-line rip blade that does very nicely, but as a matter of policy I leave enough on that ripped edge to rejoint for the glue up. Reason being here, that I will get a more precise 90� from my jointer than from a table saw blade. A finer glue face means less pressure is needed with the clamps and a finer glue line will result.
Re: Ripping on the bandsaw
Steve in Phoenix
I've been rolling around the idea for an uber-bench of sorts. A narrow, long bench with a vise at one end and dog holes along the top. It could be used for side support for cutting panels on the table saw, outfeed for the band saw, and support for long pieces on the drill press. I keep getting caught up on how to do the adjustable legs though. Attach the table top to a $150 scissor lift? Independently adjustable legs in a way that I can't drop that end of the table onto my head? If I can get it worked out, I'll have a really versatile addition to the shop...
Adjust-A-Bench?
My ol' pal Geoff Noden sells his invention called the Adjust-A-Bench and it might be just what the doctor ordered. Google him.
Ripping a lot of what?
Bill Tindall
Let us begin with a question, how do you want to improve on the blade you already own? What isn't it doing to your satisfaction? If it is dull, have it sharpened for $18 or so.
Do you do more ripping that a typical cabinet shop? Most, actually all that I have seen, leave a combination blade on the saw for most of their needs.
Are you ripping lots, like hundreds of bdft or 8/4 or heaver stock mostly? (If not then I think Ellis's answer missed the mark.) Then a production rip is needed, and a 5 HP motor. I have one with 12 teeth, custom made for my needs. It leaves a cut about as smooth as my chain saw but walks through thick lumber effortlessly.
Sounds like you occasionally want a smooth rip. Then you need a glue joint rip blade-40 teeth or more. It will rip slow as molasses in 8/4 lumber.
Or are you ripping thin stock? Then you need a thin kerf blade, ideally smaller than 10", with a bunch of teeth.
Who ever suggested ripping on a band saw didn' t mind spending money on blades. While it may be the safest way to rip it is also the most costly. Steel blades dull quickly which is why it is unlikely you will find a 10" steel blade now days; they are all carbide.
You description of ripping the mahogany puzzled me. I never understood the problem. I can't imagine not ripping after planing. Try ripping a cupped 6" board and you will soon see why.
If you table saw needs are typical you need a sharp combination blade which will be used most of the time. The second blade I would recommend would be a cross cut. Third would be a glue joint rip. Actually the first blade I would recommend would be a 40 tooth very thin kerf 7 1/2 or 8" blade which stays on my saw for 95% of the sawing I do to make furniture and cabinetry- safer, quieter, less dust.
Re: Worth a try
Jim Dillon
Steve,
"I learned a real fast lesson on rough ripping with African Mahogany. I ran a few 8" boards through the jointer and planer, then ripped to width. Not a good idea. I rough ripped, and ripped to final later. Fussy wood... "
Like Bill, I can't quite figure out what the problem is. I have done a little ripping and crosscutting of 8/4 and 4/4 African mahogany after jointing and planing and had no problems. Yes, I used a ripping blade to speed the process but cut oversize knowing I would touch up things later on. I also have a Tenyru full-kerf combination blade that came with my tablesaw that does an admirable job on ripping and crosscutting. A ripping blade will not give quite as smooth a cut as a blade with more teeth, but it sure should be OK for rough cutting and some would say it would be fine for glue-up as well if you chose not to joint the edge. Anyway, all the suggestions you have gotton are spot-on and building/buying an extension table is worthwhile.
Jim
Re: Worth a try
Steve in Phoenix
After jointing and planing into a nice piece of flat wood, I then ripped into strips. Each new piece warped and twisted. Thus I learned to rough rip prior to flattening and thickness planing. Not really an issue, just some banter tucked in a response.
Re: Worth a try
Jim Dillon
Steve,
Thanks for expanding on your post. Sounds like you have a drying issue going on as well. Even if the wood is fully equilibrated, internal stresses can give problems when cut. I've had this happen especially when resawing on a bandsaw, and why a splitter/riving knife is important to prevent kickback on the TS.
I'm always cautions about using a table saw to rough-rip or crosscut lumber that hasn't been flattened first on the jointer. Sometimes it is hard (especially on a longer board) to detect a slight twist in the board which can lead to some serious surprises. While I have done it, I try to avoid that scenario.
One last thing, then I'll "hang up". In my limited experience, the speed with which you push the board can dramatically impact the smoothness of the rip cut. Said another way, pushing a 40-tooth glue-prep blade fast may give you the same surface smoothness as a 24/30-tooth dedicated rip blade pushed slowly - the burning issue aside. So it is sort of a balancing act between the surface smoothness desired and avoiding/minimizing burning.
Jim
FredD
Steve,
like you stated , you learned the basics using a combo blade, many woodworkers have done the same and finally made the last step up .
The term "combination blade" is misleading in that the blade it refers to has always been called a Planer blade , it typically has four ATB teeth followed by a flat ground raker tooth, in groups around the blade.
That being said it has the drawbacks associated with trying to do two jobs well enough that your satisfied with the results and fails at both.
I have worked in and have owned Cabinet shops all of my work life and the setup is always the same.
For crosscutting on a TS in solid stock and crosscutting and ripping in Plywood ,a good grade of ten inch blade with 60 teeth ATB , made from a thick ,flat ground blank will do all of the above significantly faster and better then a Planer blade. Like wise in a rip blade use a good grade that has 24 or more teeth that are ground flat across for all of the ripping in heavy stock and or larger then usual stock runs.
The General purpose blade I described for cross cutting will do a fine job of ripping in thinner stock like 4/4, only slower and harder on the machine and produces copious amounts of fine sawdust, so the rip blade really is the ticket and contrary to what you may have heard, really the only two blade configurations you need for a TS.
This what I do when I bring a load of hardwood from the mill, I let it lay in the shop for a week or two to settle down and then plane it to a thickness slightly more then I need in the finished product and let it lay another week or two to see how flat it stays.
Then I put a straight line rip on one edge and run that edge though the jointer and stack all of the boards according to width until I start the project , be it a one off piece of Furniture or a set of Kitchen cabinets.
For Architectural Mill Work like door and window casing and base and crown mould the operation is slightly different and more continuous and done with a rip blade and power feed though a dedicated saw which sizes the stock before it is run though a molder.
But you don't need a dedicated saw for ripping unless you get into production runs.
You also don't need to worry about a less then perfect edge from a rip blade ,because you form a new perfect edge when you joint the board after ripping.
You can always visit your local cabinet shop to see how this relates to you and go from there.
FredD
Re: Worth a try
Steve in Phoenix
Jim,
The potential for problems rough ripping on the TS would seem to lend creedance to roughing out on the BS (steel blades notwithstanding as they're only $15 apiece). Going through one per job might be acceptable to save from wasting expensive hardwood.
The frustration I've had with the 4/4 material I've gotten in the past is how little extra thickness I have to work with. 13/16" leaves no room to spare.
Thanks,
Steve
Steve in Phoenix
Fred,
I usually end up back at the jointer anyway. I'm with you on the rip. On the crosscut, if we assume I will only cut wood with it, should I go with 80 tooth?
Thanks,
Steve
FredD
Steve, depends on the machine we are talking about.
On a ten inch TS or RAS , 60 tooth with a ATB grind is plenty of teeth.
Before I go further, do not run a typical TS blade on a RAS , because it has a positive hook angle to the teeth and is far to aggressive for that machine.
For a RAS use a zero or negative hook blade, also mark the two so you will not mix them in a hurry to go .
I run a eighty tooth blade on a 14 inch Makita chopsaw and it makes a polished cut that reflects light.
This is the type of cut you would look for in a mitre.
You can run eighty teeth to the blade on your TS , but it slows the cut somewhat and puts more load on the machine and really powders the sawdust.
I have seen forty and fifty tooth blades run on a saw with very acceptable results , in plywood or crosscutting.
If you do primarily a lot of cutting of Veneer core plywood with a hardwood face, you may become picky about the crosscut.
I run a test for my plywood jobs with a blade that will crosscut Birch veneer plywood. No chipping allowed.
This is a indicator of how well the blade was made and how well your TS is tuned and how well the saw shop sharpens it when you need it.
A blade that does not chip the Veneer is a blade to love.
FredD
Re: Worth a try
Jim Dillon
Steve,
Yes, your frustration is shared by all of us who buy a 4/4 board feeling assured that we can easily get 3/4 inch from the finished board only to discover that the rough board has a "slight" cup in it that makes achieving that final goal more difficult. That is why it is so important to try and pick out nice stuff to begin with as it can save a lot of aggravation later on. Sounds like you are doing just fine and understand the problems you are dealing with.
Jim
Steve in Phoenix
Unfortunately, the bearings pooped out on my chop saw, and what I want to replace it is too expensive. So the TS will have to be doing that work too.
FredD
I cut all of my picture frame mitres and Wainscot mitres on a sled set up for 45 degree cuts , running the General purpose blade of sixty teeth Steve and you can't improve on the cut.
The chopsaw is for Crown mould where it excels in ease , accuracy and speed cutting large moulding.
FredD
