Tip for refridge coils (OT)
Larry in NW Ohio
I have a tip for your refridgerator coils. I have cleaned the coils in my fridge and my childrens, and it is a PITA. So I came up with a way to make it so much easier. I went to Lowes, at the time, and got some carbon filter material. It`s 16 X48 inches and about 1/8 thick and made by Best Air out of Hampshire, Il and RPSproducts.com. I cut a strip and put it behind the front grill below the door, thats where my coils are. I also put velcro on the side and put a strip on there so the air has to flow through the filter material. I just cleaned it today after about a month and it had alot of dust on them and very little on the coils. If you have pets I found that this stops alot of dust and hair and keeps the coils fairly clean. I would suggest this if your coils get dirty very easy. Larry
Re: Tip for refridge coils (OT)
Bob Entwisle in NJ
Larry, that sounds like a great idea!
I'm gonna have to give that a try.
We have too many (4) Dogs and a cat and most (3 of the dogs and the cat) seem to be able to 'shoot' fur into anyplace that is inconvenient to clean, or in the case of the refrigerator too expensive not to clean!
Thanks
Bob in NJ
Larry in NW Ohio
Bob Look at your fridge and figure out where the air goes in, mine goes in on the right side and the front and that of course is where I out the filter. If you have a Menards big box that is where I got the last box of filter material. Lowes stoped carrying it around here. Another tip in cleaning the coils, which I have to say is probably not the right way to do it. I`ll pull the fridge out and use cardboard and duct tape all around and put a shop vac hose into a hole in front and use VERY little compressed air from the back and blow it to the front, again very easy. Some of course got out but it got clean. Another way I did it was to get the fridgs pointed out a doorway and blow, that worked very well. Larry
Get the official brush
Bill Turpin in WNC mountains
Lowes and others sell for about $6 a "condenser cleaning brush". Handle about 18", brush tapers from � 2" down to nothing. It will clean that tapered coil. One cleaning will save the purchase price in kilowatt/hours. The refrigerator should be OFF when doing this. That will prevent sucking more stuff into the fan. They sell them in the appliance dept.
Stop most of the dirt by not standing in front with the door open deciding what your next snack will be. Your shuffling feet kick all that stuff up.
