We value your privacy.
My 10 year old Jet cabinet saw is changing owners. I've removed the rails, extensions and everything else I could. It still weighs a ton. Is it safe for several people to lift it by holding on to the table top, or do we need to grab it by the base? Anybody have a good idea on how to get it into the back of a pickup or trailer?
You can remove the top and motor and it will weigh a reasonable amount for two people to easily lift. In fact just removing the top is all I did when I moved my Unisaw.
When my 1946 Unisaw made its way to my shop I used a hand truck to get it to my tailgate .I then with one other person
flipped the saw into my truck with the top down on the bed .It was easy to slide forward and strap into place.Upon arrival at the shop we reversed the process and rolled it out of teh truck and into the shop.
Yes, remove more stuff. Removing the motor may be the best thing to remove since removing it takes considerable potential stresses off of the trunnions. Might as well remove top too since you will want to thoroughly realign it when it reaches it's new location.
Put mine on a pickup by myself with the main top and motor attached. I removed the wings and rails, but that's all. I did have help getting it OFF the truck later.
I've moved my jet three times and have never taken the anything apart and my saw has 52" rails. the first time I moved it using an enclosed car trailer whose back door was a ramp. I had two friends helping me and we just scooted it up the ramp.
The second second and third times I moved it by myself in a trailer without a ramp. I used the rails as levers and tiped it up a bit to walk it to the back of the trailer and then used a pryber to lift one edge at a time and slid wood blocks under it until it was even with the trailer. the last set of wood blocks extended into the trialr so I could slide it into the trailer. it was surprisingly easy but I would recomend having a friend or two on hand to help with the pushing.
Thank you folks...tomorrow is moving day. The Jet is departing and a Sawstop is taking it's place. I'm hoping the buyer will help me place the new one in the mobile base.
