Math guru needed.
Math guru needed.
Math guru needed.
Keith Newton----Little Rock, Arkansas
I thought I had a link to a site that would give me the R of a circle with a given chord length and depth. I just cut that Bubinga board, which is 39" wide, and by bending a batten parallel to the ring, have determined that the chord depth would be 5".
What would have been the radius, or diameter of this tree?
Re: Math guru needed.
kgoring
81.05", if I understand correctly
kgoring
81.05" diameter
Robin Corell in Atascadero CA
looks like you got the answer but still don't know how to fish.
chord= the lenght of the chord
rise= the rise of the chord at the mid point or in your case 5"
[(1/2chord) squared + rise squared]devided by 2*rise= radius
I use this formula a lot in my own work.
Robin
Radius of arc
mdclor
=((((B5/2)*(B5/2))/B6)+B6)/2
Copy/paste this formula into cell B7 of a spreadsheet and have the chord length in B5 and the rise in B6. Robin gave it to you, but this might be a little easier to use.
Alexandre Grigoriev
If you use an arc drawing bethod that employs two nails and two sticks at an angle, you don't need to know an exact radius.
mdclor
The "*" is used by excel as the multiplication symbol. When I took algebra, we used an "x" so the two are synonymous.
I make Mission style furniture so I use it to determine the radius of the arc that I want to make. Once I know the radius, I make an appropriately sized jig to draw the arc on the 1/4" ply or mdf that will become the template for drawing the arc on the stock. I also use the template to guide the router to remove the band saw marks. You can see a couple examples in this pic.
Let me know if any other questions.
Dan Donaldson
The * represents multiplication. Other symbols you might see at times are the backslash / for division, and the carat ^ for exponents (ie 2^2 represents 2 to the second power)
Thanks All,
I guess I have been out of school too long. This is the first time that I ever knew that * ~ = X. Now I understand the equation.
Considering myself a tree-hugger, I know how hard it is to get my arms around one that size. There was a little decayed sapwood on each edge, so I would like to think that the tree died of a natural cause before it was cut.
Funny You Should Ask
charlie belden
I'm doing two intersecting arcs multi-center pieces and I wanted the radius of each of the arcs of a piece I just did. Turns out I went through the math back in '05 for an arch over a wine cellar door.
The equation you're after is
R = ( C^2/8xO ) + (O/C/2)
Radius equals C squared divided by eight times O plus O divided by half of C
Where
C= chord length
O = offset distance from the middle of the chord to the circle of radius R
So - the diameter of the tree, given a chord length of 39" and an offset from the cord to the circle of 5" comes out to be about 81",
assuming the growth rings are a) close to perfectly round and b) perfectly symetric on center - which few trees are.
Andy Lincoln,in Dearborn,MI
Keith,
I read this thread last night and today was able to get into the shop where I had the book with this formula in it.I use it frequently.
r = (m� + �c�)/2m
Hope this helps,
Andy
