Dust Collector Died
Dust Collector Died
Dust Collector Died
Bartstar
My many year old Penn State Industries dust collector is giving me trouble. This is their near the bottom of the line 700cfm unit. I used in initially today, hooked up to my jointer. Everything worked fine. About 15 minutes later, I hook it up it up to my Planer, throw the switch, and it just doesn't even start. After several attempts, it occasionally makes a sort of ping sound right when I throw the switch. I already checked to make sure it wasn't clogged. Can't see any sort of reset button on the outside of the motor.
Can I easily fix this? If so how. If not, I'm looking for suggestions for a replacement.
Re: Dust Collector Died
I would check the switch as a place to start.
If you have a meter you could check to see if the switch energises the leads to the motor. If you don't have a meter you could wire the cord directly tot eh motor and leave the switch out of the circuit and then plug it in to see if it works.
Then there is the start capacitor and the start windings. Maybe someone else can tell you how check them. I would either replace the capacitor or take the motor to a shop for a check up.
del schisler
look at the end's of the cap's and if not flat where the spade lugs are Or push out than the cap is open It is probly open If you have a volt meter neg to the neg and postive to one side of the cap If voltage their than their should be voltage on the other side This will be AC voltage The voltage should be what the line voltage is Not like 1/2 or less Their may be 2 cap.s on the motor depends which you have if so check both cap's If you don't come up with anything their is a start run plate inside the motor That would probly requir a motor guy for this A easy fix I have done this a few time Been in radio and tv repair so not a big deal for me good luck
Its the Switch
Bartstar
Hi Barry,
Thanks for the advice. I took the switch cover off, removed the 2 wires connected to the switch, taped them together with electrical tape, and plugged the collector back into the wall. Sure enough, it stated right up. So, I wonder if I should just call up Penn State tomorrow and ask for a replacement switch, or are there better ones to be had from electrical supply stores, assuming I can find one the fits into the casing where the current one resides.
Best Regards
Bart
Re: Its the Switch
Larry in NW Ohio
Bart Before you do anything try taking compressed air, unplug the DC first, and blow around in the switch. There may just be dust in the points. Larry
Re: Its the Switch
I agree with Larry. Blow out the switch. The one on my Performax got glitchy and I ordered a new one. When the new one came I took the old one apart. It was basically snapped together. It had at least a teaspoon of sawdust inside. There was nothing at all wrong with it other than too much sawdust to allow contact. The next problem was I could not for the life of me get it to go back together right. I guess I was not holding my tongue right or did not have enough fingers and toes. Since I already had a new one I gave up. I still wonder why they put an "open" switch on a machine that makes dust as it's essential operation.
You may be able to buy a replacement switch locally. Lowes has some and so do electrical supply houses and places like Grangers. Not sure you can get exactly what you need but you might. If you must buy one, be sure to get one that will carry enough amps for the motor.
Re: Its the Switch
Bartstar
I haven't had time to kick up my compressor to try blowing out the switch. However, I did call up Penn State Industries today, and even though my collector is 9 years old, they are sending me a new switch at no cost.
Regards
Bart
