Green wood band saw blade recommendation
Dave Thompson
I've been resawing some green ~10-12" logs of osage orange and hop hornbeam and while I've had some success, I'm not happy with the process. I'm using an ordinary steel 1" blade with a 3/4 TPI on an 18" Laguna, with a home-made log sled for stability. The blade has a pretty narrow set, and thin kerf. I'm thinking I would be happier with a much wider set or perhaps wider kerf that a carbide blade might offer.
I was wondering anyone with experience resawing green logs might be able to offer advice on a particular blade & vendor, or any other advice.
On a related note, anyone have experience over tensioning a bandsaw blade? I tend to go with the recommended amount based on blade width, though am questioning this with the 12" log. Do blade frequently break at over tensioning, or is more likely I'll just get outward deflection? I suppose it depends on the amount of overtensioning... or do you think I should stick with recommended tension, and just get a wider blade?
Thanks,
Dave
Re: Green wood band saw blade recommendation
Doug Reynolds
A hook-tooth blade is supposed to be more aggressive and, depending upon the thickness of the wood, you may have too many teeth per inch and the gullets cannot clear. I am interested in seeing other responses as I am sure this is a common question among turners. Maybe you should post this on the Turners message board also if you haven't already.
I use 1/2" blade with 3tpi. I cut up a whole Osage orange log for a guy just recently. I am using cheap $6 blades that I get from my local blade sharpener. They dull pretty quickly cutting dry Osage and Black Locust but hold up really well on green wood.
Robin Corell in Atascadero CA
You are on the right track with more set but I think a carbide blade is a bit overkill. Price one out along with how much it runs to get one sharpened and you will know what I mean. I used to use a bi-metal blade with 2x the normal amount of set. Unfortunately my supplier can no lnger get that blade for me. Ask your supplier what they have and stay away from the narrow kerf stuff with green wood. Highland Hardware sells a blade for wood turners to cut green wood. I have been happy with their other blades.
I do add a bit of tension when I open the guides up to max resaw height. I don't like running extra tension all the time. Actually I tend to run a bit less tension than most. By running less tension the blade will not track a line if it is not 100% sharp.
Robin
fewer teeth
Dave,
I once had a wonderful green wood blade for a 14" saw that I modified from a 5/8" 3 tip blade. When sharpening with a dremel, I broke off and ground down every other tooth. This made a 1.5 tpi blade that cut far better.
Since then I use an 18" saw with a wider 3 tpi blade, but when I have some green resawing to do I take it to my Woodmizer back behind the barn - exactly what it is made for!! (1.5 tpi blade again)
If you can find a small bandmill owner in your area, I'll bet he/she would be happy to slice up your green wood for little or nothing. The Woodmizer company keeps a list of owners that are willing to saw for others.
If you are getting side deflection, I found this contributes: not enough tension, blade not sharp enough, buildup of sawdust/resin on the inside of the blade (gets smashed between blade and tire). To remove the gunk, I hold a piece of non-ferrous metal to the side of the blade while running - in the shop I use a piece of square brass tubing. I do this on the woodmizer as well but with a different tool. (scrub pine is the absolute worst for buildup that I've encountered)
A good tension gauge is helpful. Iturra Design sells several models.
Dave Thompson
Thanks Robin, Just picked up a saw tooth set tool and may try it out on the band saw blade I have.
Re: fewer teeth
Dave Thompson
Thanks. I'm actually using a 1.5 TPI blade (not 3/4 like I said earlier). Something interesting I notice in the replies is that people are using narrower blades than my 1". While I know I'd have to reduce the tension, perhaps a narrower blade might be easier to correct after a drift. I think I'll be experimenting with different width blades, and more set on the blade.
Re: fewer teeth
A smaller blade is a WHOLE lot easier to tension properly on a given saw! And a narrower blade can have less problem with resin buildup and friction.
