A55 Smoothing Plane
DC filter cleaning
DC filter cleaning
DC filter cleaning
Jerry Gibbs
I am trying out a used Jet DC1000 rollaround dust collector. The Filter is rigid paper and is very dirty. The owner says the interior paddles don't work well. Can I clean the paper with water from a hose without harming the filter?
Re: DC filter cleaning
Ask JET But
Probably not. Many such filters have a coating on their interior surfaces that will degrade when went.
Clean by removing to the outside, tapping gently on the ground, then blowing air outside-in to dislodge the fines. You do, of course, want to be wearing a mask when you do this. Remember also that some dust-cake on the inside is not necessarily a bad thing as it actually improves the filter's fine dust capture.
Not positive, but pretty sure that will ruin the filter. You can blow the filter somewhat cleaner with an air compressor. The other side of the equasion is that the filter will just get dirty again fairly quickley. Part of the process is that the filter packs up ith fines and that actully increases the filtering effect. It reduces the air flow, but decreases the particle size the filter collects. If you blow it out with an air nozel, be carefull. You can blast a hole in the filter and ruin it.
Dave Paine
I have a Jet DC with a filter cartridge. Likely a larger version of your machine.
I would not use water, as others have said, likely to ruin the cartridge.
The paddles are ineffective. I clean my unit with a brush to extract most of the dust from between the pleats in the cartridge, then use my shop vac and compressed air.
Messy but gets the cartridge back to normal operation. The fine dust can build up and act as finer filtration - but at the expense of pressure drop which means much less flow and suction.
Larry in NW Ohio
I have an Oneida 3HP with about a 6 ft. filter. The way I clean it, only once so far in 6 years, is to take it off and go outside and put it in a cradle I made for it so no part of the paper filter material touchs the cradle. I close off one end except for a hole for the shop vac hose. Then with vac running I use compressed air to blow into other end and get as much dust as I can out without getting to close to the paper material. If need be I`ll turn things around to get the other half, and maybe put two vacs on if needed. Does a great job. Larry
Andy Wright - Allen, TX
With my Jet, I often clean it by tapping the sides with a piece of scrap wood rather than the paddles
Another thing to try is compressed air blown in from the outside.
FWIW, I wouldnt use water on mine
The paddles in my JET cannister work very well.
Dave Bair, Eaton Rapids, MI
