Re: very small router recommendation
Joe Burke
I have a Dremel with a router base that I'm sure I purchased at Lowe's or somewhere similar, so it's nothing special. I refit it with a 1/4" plexiglass base plate, and I use it in just the manner you describe. Whenever one of the machine tool companies has a sale on carbide end mills I'll buy two or three 1/8" end mills and I use those to cut hinge gains. You can find an amazing array of tiny end mills with 1/8" shanks for inlay and the like.
I haven't run into anything yet that a sharp 1/8" end mill can't handle. I usually cut as close to the line as I dare and chisel the rest. Having said all that there are some downsides to my setup. While a sharp 1/8" end mill works you simply can't hog out a lot of stock at a time. Patience is a virtue here. Since I'm not routing hinge gains daily it's not too much of an issue for me. The Dremel router base I have works, but it's depth of cut adjustment is not ideal. Okay ... it's awful really. It gives new meaning to the word coarse. I'm pretty sure Dremel, and others, have new and better bases available now. I think of getting one every time I cut hinge gains but have yet to follow through.
The Dremel works well for me, but like I said ... Find a decent base and accept that removing the waste is a nibbling process.
