Gluing felt in drawers
Virgil Johnson
I need to glue felt in the bottoms of several drawers that have .020 thick sheet metal bottoms. I can't imagine spray being very neat and I want to keep glue off the sides of the drawers. How would you do this?
Virgil Johnson
Re: Gluing felt in drawers
JoeW in Detroit, MI
I've seen plans that call for using pposter board. Cut the board to size, glue on the felt and place in the drawer. This has the advantage you can replace the felt if ever the need arises.
that's how I've done it
Bill Tindall
Spray adhesive on the mat. There is a clever cut one makes at the corners so there isn't a wad of felt under the corner where the several layers fold under. I can't describe it . I think quilters use it.
T Rex
My wife, the quilter, has these suggestions
First suggestion
1. Cut poster board to the exact dimension of the drawer.
2. Cut the felt about 1/2� bigger than the poster board.
3. Spray the poster board and lay the felt on it so that there is approximately 1/4� of felt around the poster board.
4. Let it dry.
5. Place the piece on a flat surface with the felt on the bottom.
6. With a rotary cutter, using the poster board as a guide, cut the felt to the exact size of the poster board (Rotary cutters can be purchased at most sewing centers).
7. She would not wrap the felt under the poster board.
Second suggestion
Use a non-slip rubber mat between the bottom of the drawer and the felt. The non-slip rubber mat can be purchased at Target or Walmart.
I made a bunch of boxes and wanted to line the bottoms with velvet. I cut poster board as others have suggested, but made it about a 1/16" undersized. Cut the Velvet about two inches over sized and glue it on with the board centered on it. Cut the corners off at about a forty five so that the cut runs right to the corners of the board. The angle is not critical, because when you fold them under, they will match almost anyway you cut them. Fold the flaps under and glue them. I think I used glue sticks to glue them on. Sticking the board to the cloth is not really critical. Just enough to hold the cloth still while you clip the corners and turn it under.
You would need excellent glue to hold the edges down securely if you trimmed them flush as suggested above. Folding the edges tends to lock them even if the glue is not great.
Check the latest issue of Woodcraft magazine
Craig Bentzley explains it nicely. Basically, it is about how to lay out and cut the parts, apply the adhesive without danger of overspray, and install the completed felt/velour/velvet panels in your project. I have been using this method for a long time and would not try it any other way.
Jerry
I agree with the poster board. I used poster board but instead of glue, I used the thin carpet tape (double face). Worked great on a silver chest years ago.
I use PSA backed felt
Robin Corell in Atascadero CA
I use PSA backed felt that I buy from the manufacturer direct rather than from one of the wood working catalogs. The stuff I have is 50" wide and to meet the minimum order of $50 I ended up with 10 yards. The paper backing is stiff enough that it makes it easy to lay out an cut what ever size I need. There is a bit of a learning curve. if you peel all the backing off the felt shrinks up a bit so I found the best way is to peel up one edge and cut about a 1/2" strip of the backing off. I can then lay the part with the backing on it into the drawer and get it positioned perfectly and press down on the part without the backing to secure it in position. I then lift up the loose part and peel the backing off, but before it all comes off I cut the backing to leave about a 1/2" strip so I can use that to apply a bit of tension while laying it down to keep it from shrinking. it sounds awkward and time consuming but it takes more tome to explain it than to do it.
I did a 8 drawer jewelry box with metal drawer bottoms as well as a 12 drawer silver chest with hardboard drawer bottoms. Both times I ended up with excellent results and the clients were happy. I also did the drawer sides on both projects and on the 12 drawer chest each drawer also had a sliding tray that was also lined. It does take a fair amount of time but the results are worth it. the edges would not curl even when blowing out dust with compressed air.
Robin
Marv
Virgil,
When I was 22 years old, I built an 18 drawer machinist tool chest. I glued the felt in the drawers with just plain ol Elmer's white wood glue. I lined the bottoms and the sides of the drawers. The sides were done with four different pieces after I did the bottoms. Some of the drawers are only 3/4" deep. After 50 years, I'm still using the chest. None of the felt has ever come loose. The glue didn't soak through the felt as I expected. I bought the felt from a sewing materials store, the thick stuff. A little thicker than 1/16". I applied the glue to the wood and just layed the felt on the glue and smoothed it out until it was flat and even. Once I did that to a single piece, it stayed put and I could go to the next piece without waiting.
Marv
