gluing leather
gluing leather
gluing leather
Carol Reed
I am making a binder for my worship service materials. I have some Moroccan Leather that I want to use for this project. So, two issues.
The first is gluing the leather onto very stiff cardboard. Wanted to use plywood but couldn't find any 1/16" thick. I got this stiff cardboard at a scrapbook store. Though I might use a 3M spray adhesive or water-base contact cement. Strangely enough, I could only find solvent based contact cement locally. Will have to look further as I am also making a new kitchen counter top and planned to use WB contact cement for it. Anybody ever glued real leather? What do I need to know?
Second issue: I want to make it about 2/3's the size of a regular 3 ring binder. Now I need to modify the ring binder thingie. I want 1/2" and cannot find, after much Googling, a three ring binder of the right length for this special purpose binder. Think about shortening it by about 2 inches. (And yes, I have an adjustable hole punch to accommodate a custom binder!) Anybody ever fool with the mechanism of a 3 ring binder? Your insight would be great.
Re: gluing leather
Re: gluing leather
FredD
Ii crafted Leather for many years Carol and I can tell you there are two glues used to bond it.
Rubber cement is a readily available glue use for temporary or permanent bonding of Leather and it can be easily removed if you want to move the leather or take it off.
The other is Barge Cement and you will find it in leathercraft stores and Shoe repair shops.
You didn't used to be able to get it in the mail because of its flammability and I never got in it a container smaller then a quart.
I would caution you to use only one or the other of these to prevent staining or damage to the leather.
Your English Morocco is a fine Goatskin , hand picked and hand textured and expensive and makes the best looking of all book cover materials.
So I would say a trip to the Shoe repair for a bond that you can't take off or any Hobby shop or Hardware for the rubber cement.
FredD
Re: gluing leather
Re: gluing leather
Keith Newton----Little Rock, Arkansas
I have used spray contact with no problems. If it is a thin soft leather, I found it easier to leave it laying flat on a surface, then laying the substrate on top of it. It is hard to pick up a limber sheet of leather after the glue is on, without it accidentally folding over, sticking to itself, or the wrong place.
Re: gluing leather
Re: gluing leather
Al Stokka - Cambridge, Iowa
Carol,
Expanding on what Fred said:
I, too, have done leatherwork for many years. For a permanent bond I use rubber cement. Coat both surface to be bonded. Let the cement dry! Then, carefully, bring the two items into contact and press together. Done.
Instead of cardboard or plywood, consider aluminum sheet for the stiffening material.
For your 2/3 size binder mechanism, have you looked at vinyl binders? I would buy one of those, disassemble and retain the ring mechanism, and use that for the new binder.
Pictures please, of the completed project.
Al
Re: gluing leather
Re: more on binder mechanism
Al Stokka - Cabmridge, Iowa
Carol,
More info on the binder:
Staples has 1" ring binders in 5 1/2" x 8 1/2" size. They are called memo-size binders. I was able to find a 1" ring, but I know they are made (or al least used to be made, cuz I have one) in 1/2" size.
www.staples.com and search for item 175521 or
http://www.staples.com/Avery-Memo-Size-Round-Ring-Binder/product_175521
Al
Re: gluing leather
Before you begin, Carol...
David Barnett - SW FL Gulf Coast
Leathers such as levant, morocco, shagreen, vellum and so on, should be pasted or hide glued only onto wood, binder's board, or mattboard (and a few less common substrates). Barge's and 3M cements, while acceptable for some types of leather craft, have no place when creating covers for books, albums, or slipcases. There are other issues you may wish to consider, as well - none of them difficult (including glueless variants) - which will greatly improve your outcome. Email me and I'll get back to you, so as not to entirely stray off-topic.
I hope I didn't offend anyone. I use Barge's and 3M spray glues where appropriate, but never for bookbinding and casemaking. Right now I'm covering two floor-standing speakers in parchment, so such things have been on my mind.
Re: gluing leather
Re: gluing leather
Bill Turpin in WNC mountains
+1 for Barge. The best thing for PERMANENT shoe repair!
Re: gluing leather
Thin plywood
Neal in San Jose
Very thin, down to 1/16, is available at any hobby shop - airplanes, trains, slot cars, etc. They all use the thin stuff and I find the 1/8 size very handy for jigs and fixtures. I've bought it in sheets 24" x 24", and have seen it 3 feet wide. If you can't find it locally, just Google "hobby supplies". I did and got a jillion hits. I didn't follow it any further, but I'll bet you can get it on line.
Re: gluing leather
Re: Before you begin, Carol...
Carol Reed
Thanks, David. I will get back to you, though since others may be interested it is always good to have these discussions on-line. My email is readily available so you can PM me if you wish.
This is a longer term project. Right now I am consumed with Easter services and my schedule has not real breathing room until after the middle of the month. Just preparing in case I have to order something. Living in the mountains of Arizona means planning ahead!
Re: gluing leather
Carol Reed
I found the 1" binders in the memo size binder, but for the life of me I cannot find the 1/2" size.
Any clues?
Re: gluing leather
Re: Thin plywood
Carol Reed
The hobby shop available to me without driving 100 miles one way didn't carry it. The scrapbook store had the heavy card stock they cover for scrapbooks. So I got a couple of pieces of that. Should work fine.
Re: gluing leather
Clint Searl
Re: gluing leather
Clint Searl
I can't help with the binder geometry, but consider a piece of Formica as the base for the leather.
Clint
Re: gluing leather
Re: gluing leather
Be careful coating one side of a stiff piece of cardboard or even thin plywood with glue. It can cause serious warping. Test first. Perhaps non-waterbased glues would be better, I don't know.
Re: gluing leather
Re: gluing leather
Chicago Bob
try googling Tandy Leather, if they don't have it, no one does! :D
Re: gluing leather
Larry in NW Ohio
Carol I have some 1/16 ply. I get it from the flat intiorer doors of a house, or a lumber yard that have damaged ones. I just cut the edges off, about 1 1/2" and the plys are glued to honeycomb cardboard, atleast the ones I take apart. Just need a little sandinr on the inside. Larry
Re: gluing leather
Carol Reed
Part of the issue with living in the mountains of Arizona is the 100 miles from major shopping. HD does not carry door skins here any longer, and nothing thinner than 1/4". That's why I went with the heavy card stock the scrap-bookers use. They glue fabric on them and are also interested in how leather might work.
Next week I have a trip planned to the big city. Probably will stop at Micheal's or Hobby Lobby. Just to have some in stock. Also have to dig out the leather and see what kind of shape it is in.
Right now, I am busy with Easter.
Thanks for the great input. Lots to think about, and I will have to study Tandy Leather's website to see what else I can glean. Maybe even a new tool for skiving the leather. How can a project get any better than one that requires a new tool?!? :D
Re: gluing leather
Source for 1/2" ring mechanisms
TalasOnline.com has two shorter length 1/2" ring mechanisms. Although I've yet again lost my 'link option box' and the smiley faces, etc., I'll post the direct URL in its less friendly form:
http://apps.webcreate.com/ecom/catalog/product_specific.cfm?ClientID=15&ProductID=17821
Re: gluing leather
Carol,
I found one here:
http://www.lintonlabels.com/littleringbinders/littleringbinders.html
referred to as a "view binder." It has a clear vinyl overlay.
Also, the web page is a bit hard to read (layout wise) but I got a kick out of it. No voice mail! My kind of folks!
Al
Re: gluing leather
Re: gluing leather
steve mackay
Elmer's Yellow. I glue leather to wood, cardboard, well, everything it says on the bottle I guess. Never failed yet.
Re: gluing leather
David Barnett
Paring leather with a spokeshave - article *LINK*
David Barnett
"I will have to study Tandy Leather's website to see what else I can glean. Maybe even a new tool for skiving the leather."
You may already have one or two tools for paring/skiving that beat anything from Tandy.
One is a simple plane blade (narrow is best) or other piece of tool steel that can be ground into either a Swiss or English style paring knife. Wrapped in thin leather or affixed with a handle and you're ready to go. Well, with a bit of practice, of course. Look at Jeff Peachey's knives for examples:
http://jeffpeachey.wordpress.com/knife-catalog/
Spokeshaves are easy to modify and do a fine job with less learning curve and "workmanship of risk". I've included a link to tell how.
Get a reasonably straight-edged slab of softish stone* or Corian so your knuckles clear the workbench top, strop, and have at it.
*Printmaker's litho-stones aren't so common these days, but there's alabaster, marble, and whatever's local. I use my granite surface plate in a pinch.
Tuning a spokeshave for paring leather
Re: gluing leather
Re: Paring leather with a spokeshave - article
Carol Reed
Thanks, David. I've saved the spokeshave file. I have one that I rarely use, so some modification is in order.
I do have several methods for sharpening as I am also a turner. I have a strip sander with a leather belt and a green honing stick that puts a very sharp edge on a tool. I also have a high speed grinder that makes short work of reshaping metal.
Now some time to work on this would be nice. Thanks for your input. You have been very helpful and full of great information. If you think there are other things I need to know, please continue to share. I very much appreciate it.
When I get to this project I will do a pictorial progression and post if others are interested.
