Re: bristle skirt for dust collector *PICs* *LINK*
Alan in Little Washington (NC)
Don, thanks for stepping in! I was out of town so couldn't respond.
Disclaimer: My rig is a dust shroud NOT a blade guard!
I built my rig for 4 reasons:
(1) I didn't want a big plastic shroud
(2) I didn't want a parallelogram or other complicated mount
(3) I wanted something that the stock could easily push out of the way
(4) I wanted something that would still conform to the stock when I fed it into the blade. Big gaps are left on the sides when stock is fed into most other hard dust shrouds.
The bristles- I used bristles I canabalized from a broom. Truck and RV splash guards are NO GOOD, too thick and don't have enough bristles. The ones I got from McMaster-Carr (see Don's post) are much better than both. Whenever I get around to installing the new bristles I will use angled mounting strips (see MM-C)
I mounted my abbreviated plastic shroud high enough so most stock won't touch it- 4" above the table. For thicker stock or when using jigs it folds out of the way. For thick stock, the blade is buried in the stock and doesn't throw much dust anyway. I extended the Lexan front so I could look down from the top to see the leading edge of the blade, pencil marks, etc.
Original, prototype shroud:
Lower unit folded:
Full rig. Ceiling mount and sway braces are adjustable. Upper braces are made from EMT electrical conduit, lower braces from broom handle left over. Small band clamps hold them tight.
I used 3" flex and 3" ASTM 2729 S&D PVC. Upper portion of wye is blocked.
Gravity and three pairs of rare earth magnets hold the lower unit down. My DC and each blast gate are fully automatic- gates are machine triggered and electro-pneumatically operated. When the saw is running, two blast gates open- one feeding the over-blade pickup, the other, the saw's cabinet. If the pickup is folded, a magnetic reed switch in the upper ply hinge plate (wires visible in pic) and a small rare earth magnet in the lower plate separate, opening the switch. That causes the over-blade blast gate, located behind a knee wall, to close. The cabinet gate stays open until I turn off the saw.
Below is a link to a rather long video tour of parts of my DC system and demo of my autogates.
DC system tour & autogate demo
