Band Saw Restoration Day 2
Ken Bellock (Houston, TX)
I called MiniMax today, but was only able to get ahold of the parts department. Out of curiousity I asked how much it would cost to get a replacement set of tires. They said for my model that they do not sell the tires by themselves, but that they do sell the tires with the wheels attached... the wheels were not free in the deal. Though the parts guy said he didn't know for sure he said his guess was my wheels were either flat, or had a negative crown.
He did say to call back tomorrow a bit earlier and talk to the tech guys and that they should know for sure. I'll give them a call, but still couldn't stop messing with it, so I took a small needle, pushed it through the high point of the crown and marked the end with a sharpie. Comparing the penetration depth to the edge of the wheel makes it look the tires are the same thickness across the wheel, so maybe the wheel is crowned and the urethane tires will work. I think I will end up shelving the tires and bearings for another day either way and move on.
The next hang up, literally, was that the upper guide bar would not go all the way up. After removing it and cleaning everything, I can see where contact is being made with the wheel.
Loosening these two screws and making several adjustments, I was able to get the bar to sit where it was supposed to far away from the wheel now.
Re-installed the upper guide arm, and installed the new carter guides. Boy are they pretty, and we are starting to get somewhere!
Uppers were so easy, figured the lowers would be too... oh well, looks like carter designed the lower bearings for some other shaped SCMI S-45 band saw...
I could just file the hole longer, but I think i will give them a call tomorrow first and see if they are aware of the problem. Perfect time to call it a night.
Looking forward to making some dust with saw some day...
