Bandsaw Restoration Project
Ken Bellock (Houston, TX)
I'm trying to bring some new life back to some old steel. Thought I would share some pics of the process, and ask a few questions. I figure someone here has walked these steps before once or twice. My knowledge consists of a subset of what anyone would get from reading "The Bandsaw Book" from cover to cover a couple of times...
Here is the beast, a rescue from craigs list. I found her being abused in a small car shop. They had just upgraded to a bigger monster that was actually designed to cut metal, and they had no more love for this old beauty.
There was some dissasembly before I started taking pictures... Here is her pedigree.
And the rest of her...
I started with the easy stuff, installed a mobile base, replaced the V belt with a link belt.
Mounted some magnets into the stone for tuning the blade.
And did a lot of cleaning... little bits of aluminum everywhere!
In addition to removing the table, I removed all the guides, and the upper guide rail. It had been installed wrong or moved, and was grinding against upper wheel. There was some rust in there too, so it was good to get it all out, cleaned, and coated with boeshield. The lower guides looked like they had never been touched before. This is what the current rubber tire looks like.
From the picture, it may almost look ok, but there are chunks missing, and aluminum embedded in it everywhere. So sitting on my workbench is the following pile of parts to be installed. Two bearings, one for each wheel, the current bearings seem to be in great condition, but while I'm in there, why not. Two urethane tires. Was hoping to be able to salvage the tires that were on there, but they are just in too bad a shape. And last but not least, a bright and shiny set of new carter guides, yipee!
Got a good bit of work done on her tonight, but I got to go to work in the morning... a good thing I can claim, at least for the next couple months... and I got stuck, so it was a good time to call it night. My first question for those more experienced then is how to get past this first hurdle.
I took the bolt off that secures the bearing to the axle, but the wheel will not come off. I don't want to force it, or pry it off (I've already paid enough for the parts I have sitting on the workbench!) so how do I get it off safely? I know once it is off to tap the bearing out with a block, and then to use another block and a clamp to press the new ones in. Just need to figure out how to get the wheels out first!
Thanks in advance for any advice you can throw my way, I'll post more pictures if there is an interest as the project unfolds.
Ken
