We value your privacy.
I have mentioned I bought the Bosch Multi tool. It came with one blade that looks as much like a spatula as a saw blade. New blades are about $20. Seems a lot. This ain't a dovetail saw. I have not counted them, but the teeth appear to be about 32 to the inch and they appear to be equilateral so they will cut in bot directions. The gullets are so small I don thank any triangular file I have would work. What can I use to file the tiny teeth?
PS, for other multi tool owners, What other blades do you like and have you found a cheap source?
Barry, might I suggest you take your blade to the local Harbor Freight store and look at their multi-funtion tool and see if their replacement blades will fit on your Bosch tool. As they advertise you can buy three different blades in a package for only $9.99.
I recently bought the rockewell version for a remodel project and It has been a great tool. I use the metal/wood blade and after paying $20 for a replacement I started resharpening the old ones. I have a fordom grinder and use a diamond cup wheel, but an abrasive cut off wheel in a dremel would work. I have to use my magnifying hood thingie so I can see what I am doing and the teeth come out looking a bit less even than I's like but it cuts just fine.
The angle on triangular files are too steep. You can buy diamond files and small files from RioGrande.com. The set I have has a very narrow file with a sharp edge that would easily reach into most things other than Japanese saws and might fit those.
For years I've had a Fein and they were the only game in town. When all of the competetors showed up, I expected the blade prices to drop, but I haven't seen that. Usually, when I'd need to sharpen, it's because I've "cleaned" most of the teeth completely off by hitting a hidden nail or something, so I don't bother. I picked up a Dremel replacement blade for about half the price of a Fein, and it fits and seems to work as well as a Fein. I don't know if it fits a Bosch. I haven't tried a Harbor Freight, but they will be my next stop!
Question: Have you burned your fingerprints off yet? Those blades get HOT! I'm pretty sure you can figure out how I know that.
Slim-taper is the name for triangular files. I think it is 6".
I need a magnifying visor to do a good job. I probably only takes about two minutes for about two strokes per tooth.
I would imagine that the original grind had some set, and alternating bevel on the face grind, but after I loaned it to a carpenter out on a job-site who plunged through into plaster, I couldn't tell if that was the case, so I just filed straight across.
I just hold the motor between my knees while sitting on a low stool, and file without taking the blade off.
Since I am right handed, I hold the file with that hand. But the left hand plays a big part. Besides pinching the blade between finger and thumb for support, I use my left thumbnail to guide the file to the next tooth. Before lifting the file to move to the next tooth, I place the thumbnail against the file, with it arced back a little. Then I lift the file a little, and roll the thumb forward a little, which indexes / guides it to the next tooth.
If you make the habit of sharpening when it first starts to dull, one stroke will do it. After filing all teeth, get in some good light to look for shine from any missed dull teeth and take another light stroke where needed.
I hope this helps, it sure works for me. There is probably a video out the instructing how to use this tool, but I will just throw out this one tip. Don't just plunge straight in with the whole blade, and all teeth cutting at once, but rather swing the butt end of the tool back and forth, to rock the blade from side to side. This action reduces some of the friction, and gives the chips a way to exit, rather than being trapped between the teeth with nowhere to go.
on the way home today and bought a three pack of blades. It had one saw blade and two scrapers. Wish it had been three saws, but the price was right. Thanks Joseph.
Interesting. The hole pattern is identical to the Bosch pattern, but the Bosch has sort of rounded square holes and the HF blade has round holes. The little posts line up but will not fit the hole. There is an adapter plate that has a bunch of little pointed pins and allows the blade to work. I am still wondering about drilling out the holes, but this is all good news. And they have a variety of blades that are reasonably priced.
Now to see how the cheap blades hold up. Thanks again
