need router bit for shoe molding
Bill Tindall
Shoe is not quarter round. Typical shoe is something like 3/4 tall x 1/2" deep. Does anyone make a router bit to make shoe molding?
Bill Tindall
Re: need router bit for shoe molding
a. heath
Mr tindall,
I use my shaper with a thunbnail bit (for tabletops). Set the cutter so that it only uses a portion of the rounding radius and use a fence for the half-inch stock.
Robin Corell in Atascadero CA
Try either a 3/4 or 1" roundover bit on your 3/4x 1/2 stock with out tacking a full cut. Some times it works best on over size stock that you rip the moulding off of after you route it.
Robin
FredD
Eagle router bit #169-2015 is the profile most used for Shoe mold.
FredD
Bill, I have a thumbnail bit and it would work. Run it on the edge and the shoe would be "laying down". Rip it off and stand it up. It has a guide bearing, but that would not help because the stock would be too thin for it to touch the bearing. This is a fairly big bit, about two inches in diameter and expensive (to me) at about $60. You could run it in a router table and it cut pretty sweet.
John McGaw
Google for "shoe molding router bit" (without the quotes) for the answer. Hint: they aren't cheap but if you are doing a lot of sticks and have suitable wood and the time I guess it would be worthwhile.
agree, and....
Grant in Iowa
These guys are right on here. I made a bunch for my house and took the following steps to ensure a good safe production run:
I used wider stock and shaped both edges at a router table on several boards at one time. Then moved to the table saw to rip off the edges of each board to complete each strip.
I used extensive feather boards and board buddies on my table saw to make the parts accurately and safely.
Regards,
Grant in Iowa
Lee Valley 16J5572- perfect
Bill Tindall
I need to check my router bit collection before asking these questions. The LV bit is a perfect match for shoe molding. I suspect it is designed that way since it reproduces a Stanley 55 pattern.
Re: Lee Valley 16J5572- perfect
ash
http://www.leevalley.com/wood/page.aspx?c=2&cat=1,46168,46177,54889&p=54889
