Dowel size vs: Hole size
Bob S
I am having a problem with dowels purchased at Lowes. They SEEM to be a little smaller than expected. I can't be sure (can't remember, that is), if a 1" hole, should be drilled for a 1" dowel, or if a smaller hole or larger dowel needs to be used.
My forstner bits seem to cut a very good, 1" hole, and I seem to recall that a 1" dowel SHOULD fit in snuggly. Please help.
Bob
Re: Dowel size vs: Hole size
Dale Lenz
You are correct, Bob.
Dale Lenz
1" =1", back when I used dowells I used to drill the hole size I needed in a block of wood and take it with me while shopping for a dowell.
Re: You are correct, Bob.
Jesse Cloud
I don't know how they do it, but I even find that Home Depot dowels aren't consistent in the same piece. That 1 inch dowel might be 1.1 on one end and 0.95 on the other.
Anyone out there make their own dowels?
Dale Lenz
Spent a whole weekend once
Dale Lenz
making dowells of different flavors. Learn how by reading one of Patrick Speilman's books, using a router, elect. drill and fabicated jig. Learned quickly why dowells are not made out of ERC and some others, they break during the process! Calculated I made 150 dollars of dowells, 1991 prices, during that weekend, :D
FredD
Jesse, yes I make them using Lee Valley dowel cutters in 1/4", 3/8th's and 1/2".
The beauty of these cutters is that they allow for size adjustment up or down and naturally you can match the wood your using .
FredD
Use a draw plate
Robin Corell in Atascadero CA
I always take my dial calipers with me when I go to buy dowel. I also have a draw plate I made when I was an apprentice and I use it to resize the dowel after I cut it into the lengths that I will use. Lie-Nelson sells a very high quality draw plate for resizing dowels and at a very reasonable price. In fact the one they make is nicer than the one I made myself and I have thoughtabout upgrading. If you would like to make your own you need to drill the hole undersize and then use a reamer size the hole and make it round, a twist bit will make a slightly three sided hole in metal plate.
Robin
