We value your privacy.
I'm thinking about skimping, and using plywood instead of oak or pine flooring boards.
But I'm a little worried about voids in the plywood, and crushing under the wheels of tools as I move them around. And if I get good enough ply, it will approach the expense of real flooring, right?
I have a plywood floor in my shop. This is 3/4 ply over 2X6 pressure treated joists resting directly on concrete. This has been in place 14 years without problems. However, I do not routinely move machinery from place to place. It is much easier on the feeet than concrete as well. I also run dust collector lines under the floor to several machines. This avoids clutter of ducts and has produced no problems.
You didn't say what the plywood will be supported by ,but here is what I did and I have never regretted it.
My shop sits on a six inch slab , which in turn has 2x4 sleepers laid flat on 24" centers.
This is covered with 1 1/8th inch thick 2 for 1 construction grade plywood sub-floor decking.
For the finish I cut 1/4" thick tempered Masonite into 15 7/8ths sq. tile and laid them with PL400 adhesive and finally on Porter Paint's advice used a two part epoxy paint made by them which is nearly as hard as glass.
I also slightly chamfered the tile on the router table which gives a pleasing detail to tile and reduces any chance of uneven edge height.
This floor is easy on the feet and legs, does not deflect under normal shop conditions and the paint is 12 years old and still looks new , except for the occasional stain or paint drop.
If you use construction grade plywood rated for the span between joists centers , you shouldn't need to worry about "crushing ".
Remember , this isn't a house floor , stiffness is what your looking for.
I'm on a slab and wanted some insulation as well as a more comfortable surface. I ran 5/4x6 PTSYP sleepers 24" OC on the flat, filled iin with 1" styrofoam, and overlaid with 3/4" 4x8 T&G Advantech decking, painted with floor paint. Looks good, feels great, plenty of support, economical, easy to install, room for 120/240 wiring to floor outlets, and durable after six years.
Clint is correct. If you buy OSB it will be free of voids.
If you want plywood and are concerned about voids buy Underlayment grade. It used to be common and I built many houses with it under carpet. Not as common anymore with the advent of the OSB products like the Advantek stuff.
The Underlayment grade plywood has a sound face and the second ply is also plugged or sound to prevent punching through into voids.
