Have a question? Ask Woody!
Dust collection woes - Grizzly G0703 any good?
Stephen Kirk
OK, I've about reached my limit of using a shop vac to to collect dust from the jointer and planer and I'm ready to move up. So I started researching DC units ... and oh dear lord could this be any more difficult???
I came across the new Grizzly G0703 1 1/2 HP Rolling Cyclone DC. Looks great but only moves 775 CFM, which is a bit lower than some other models. 30 gal drum for collection seems OK.
I'm in a 1 car garage and space is tight, so nearly the whole shop is mobile. I don't expect the need to draw from multiple machines simultaneously. I can't afford the bigger footprint of a larger machine and I don't think I'll do any ductwork in my current shop.
So, is the machine too small for any regular work or does that seem reasonable for a single person woodshop? I know I'd have limited expandability with it. Currently the unit runs $850. The bigger non-mobile 2HP Cyclone is $950 which pulls around 1300 CFM.
Re: Dust collection woes - Grizzly G0703 any good?
Re: Dust collection woes - Grizzly G0703 any good? *LINK*
mdclor
Stephen,
I can't comment about the Grizzly, but I have 3 other machines from them and have been pleased with their value. However, just to make your life a little more difficult, I will throw the Oneida portable into the mix. :D The foot print is only 71 square inches larger and it is rated at 1440 cfm. I believe that Oneida is the clear industry leader for home/small shop dust collection machines. I have no affiliation with either company other than as mentioned.
HTH,
Merle
http://oneida-air.com/portable.php
Stephen Kirk
Wow, looks like a great machine. Has nearly everything a small shop could need. Dual drums can probably handle lots of chips without regular cleaning. Bit more expensive than other collectors, though.
Oh boy, so many decisions.
Thanks for the link. I hadn't looked at Oneida yet.
Just be sure to compare warranties.
Dave Bair, Eaton Rapids, MI
I think Merle has done you a favor. If I had known these were available I would have bought one. (They may not have been six or seven years ago.)
I have a 1 car garage shop also and I have piped it to a Delta DC with a bag. The suction is fine for one machine and sometimes two.
The real advantage to a cyclone is that the debris does not go through the impeller. I turn green wood occasional and it produces long stringy curls. They get caught in the impeller and I have to reach in there and pull them out.
Larry in NW Ohio
I agree with Merle, I have an Oneida that I had for over 7 years and it`s been the best thing I ever bought for my shop. Oh and for Barry, this dble.cyclone only came out maybe in the last couple of years. So they didn`t have them when you bought. If I were you I would seriously look at Oneida. I bet they have something for you and it is going to be very high quality. Beat of luck with what you buy. Larry Remember you get what you pay for.
what's wrong with delta ???
del schisler
I have this one for my shop I run planer jointer band saw and pick up dust off of the floor It works very well I just bought the plastic top that fits on a 30 gallen can for chips Now that works very well I dont have much over $400 for the set up I also have blast gates for each machine This can be pick up at lowes or another box store Just putting out another one to thank about
http://www.google.com/products/catalog?hl=en&source=hp&q=delta+dust+collector&um=1&ie=UTF-8&cid=9205519760026828566&ei=dzyVS-IBybO2B-HlkdUK&sa=X&oi=product_catalog_result&ct=result&resnum=2&ved=0CCQQ8wIwAQ#ps-sellers
Not a thing....
I have a Delta similar to that one. I bought it about six or seven years ago. Had a mental note that when they brought the price below $300 I would buy one. Woodcraft had a sale and I bought it.
I installed it outside my shop in a closet. Any dust it collects is gone, and I don't have to be concerned about the quality of the filter.
I am thrilled with it for what I paid. I would like a cyclone better because the trash does not go through the impeller, and I have to clean the impeller occasionally. For me it would be better if I could just blow the crap out into the woods. I am not fond of emptying the bag. OTOH, it is SIGNIFCANTLY better than no dust collector.
barry read thanks
del schisler
barry i got the
#143290
Trash Can Cyclone Lid $28.99 Mine was with free shipping from woodcraft Other's have the same Get one and you will be supprise how well it work's
That works very well You only empty the can It get's all the chip before it get's to the impeler and the bag Only the dust get's past the can The best item i bought in a long time del
Re: barry read thanks
Del, I made one out of a roll around Rubber Maid trash can. It works great. The vast majority of stuff falls out into the trash can and almost nothing goes to the bag out in the shed. The problem is that I have my shop located in a one car garage and it is too crowded. I was constantly moving the trash can separator around. So, I made it easier to remove and dump the barrel on my DC and stopped using the separator. I do bring it back in a suck out the turning shavings when I make a big mess, just to keep them out of the Impeller.
Re: Trash can Seperator Lids are Great!
Bob Entwisle in NJ
Since I installed one on on my grizzly bag type DC it catches all the chips, is easy to empty, so the bag is only dust and seldom needs attention.
This looks interesting:
http://www.evenfallstudios.com/woodworks/2008/06/27/building-the-5_gallon-thien-separator/
Some more info:
http://www.sawmillcreek.org/showthread.php?t=105730
