ADVERTISE HERE - FREE TRIAL
too tight sanding sleeves or drums?
mike American Sycamore
I am having problems with a set of drums I ordered from "Klinspore". The drums seem to be over sized or the sleeves are under sized. I loosen the nut completely off and then try very hard to push the sleeves on withour rolling over the edges. Anyone found a secret? I thought about heating up in hot water or sanding the drums down a bit. Any suggestions or tricks of the trade?
thanks
Mike
Re: too tight sanding sleeves or drums?
Lee Schierer McKean, PA
As I recall rubber shrinks when it gets cold. Toss your arbors in the freezer for a bit.
Phil Joines
It happens with my Delta Boss drums. They can be hard to get on too. Lay them on the floor, put a board on them and applying pressure with your foot roll them back and forth. Don't leave the sleve on the drum when you finish using it.
thanks Phil
Hey Phil: Worked like a champ. thanks for a great tip.
Mike
the way I learned as an apprintice
Robin Corell in Atascadero CA
When I was an apprintice one of my dities was to change the drums on the shops three spindle sanders. The easiest was is to remove the drum from the metal spindle and to insert the drum into the sleeve rather than slideing the sleeve over the drum. I know they sound like the same thing but if the drum is started into the sleeve and then the two are raised a few inches above a hard surface with the drum uppermost and droped the drum will slide a fraction of an inch into the sleeve. lather, rinse, repeat.
Robin
Ted Calver
Ted Calver
I keep a container of talcum powder near my Delta Boss. A dusting of powder on the drum helps the sleeve slide on.
