We value your privacy.
This is a question for the electrical wizards in the group. Today I was making a series of rip cuts and turned the saw on and off about 7-8 times within a half hour or so. Then when I pressed the on button, the blade started spinning, but immediately started slowing down to a stop. The saw is a Powermatic 66. I opened up the switch box and there don't appear to be any loose wires. When I press the on button, I can see a spark as the contacts jump in and the contacts stay in until I press the off button. Therefore, I believe that it is getting power. I also switched off and of the circuit breaker just to be certain that wasn't the issue. The switch is Powermatic part number 6816292 STARTER 66-BLACK 3HP 1PH #27/SPR27.
Therefore, is the switch bad? Is there an easy way to test it? Can a bad switch be fixed or do I need to buy a new one? Am I correct to assume that the motor is okay since the blade does start to spin?
Any suggestions or guidance will be greatly appreciated.
Does the motor start moving then stop every time you activate the switch? It does not sound like a start cap. If it were, the motor will usually hum then blow the breaker. It could be a faulty thermal cutout on the motor. Either that or possible the thermals in the motor starter if the switch is actually a start switch.
Good replys, but the first thing to try, and the easiest is to blow out your switch, it may just have a little dirt in between the contacts. Of course unplug your plug, and then take compressed air and just blow around in the switch. If you know how the contacts are activated, you could work them back and forth some and blow at the same time. Best of luck. Larry
If that was bad and the motor stopped rotating, it would take out the breaker. The symptoms sound like it gets power for just a moment then loses it. That is why I suspect the thermal overload on the motor rather than the start contacts or cap, or the run cap.
If the motor has power and is not turning, the breaker is going to blow.
Thanks for the responses. The likely suspects are:
1. Dust in the switch, unlikely, but the cheapest and easiest to check/repair.
Blow it out and then use a meter to insure that voltage is getting to the motor. If the motor starts then stops immediately, then you turn off the switch and try again right away. If it does nothing for awhile, then starts to work again after a wait, it is unlikely to be the switch.
2. Run capacitor, seems like a prime candidate.
If the breaker does not blow, then it is unlikely to be the run capacitor. If the motor gets power, but does not rotate, either the motor is an open circuit, (it would never do anything, but you indicated it ran for a second) , or it will pop the breaker
3. Thermal doo-hickey on the motor, another possibility.
If this is faulty, it might let the motor run for a second, but then shut off. A test would be if you try it and the motor runs for a second, then try again, and nothing happens, then wait for awhile and it tries to run again, rinse and repeat. If it is the thermal, it would trip, then reset when it cools off after a waiting time that could be short or long, I am not sure on that.
4. Start capacitor, seems less likely to me, but my knowledge base is virtually zero.
Normally, a bad start cap will be indicated by a motor that does not start, and the breaker trips.
The contacts on the centrifical switch needed cleaning. I don't remember the details and did not take pictures. It did require opening up the motor to get to the contacts.
it probly is the centrifical switch it has contact's i dont rember how many but as the motor stop's their is a spring that make's it close to the start contact's Than when you power on it put's voltage to the start cap. than as it speed's up the spin makes the contact's go to the run contact's and run cap This is how the motor goes from start to run You will have to take the bell off It will be on the end from the shaft Shouldn't be very hard to do Nothing will fall out Just look at the contact's and move the sleve on the shaft to see if it moves easely Look at the contact's if they are pitted real bad A new one is needed They can be found at most motor repair shop's Their are spade lug's But remember how they go Would be a mess for you to figure out It would be better to just take it to a repair shop A couple min and the answare should be their my 3cents inflation
I've only had start caps fail myself, motor tries to run and sounds like a big transformer humming loudly. Symptoms you describe don't sound like a start cap to me, but the other three are possiblities. I might be able to sneak into Albuquerque this weekend if you're still having trouble with it. I can usually figure out whats wrong in 2-3 times the time as someone who really knows what they're doing
Usually if the contacts or the cap are bad, the motor just hums then blows the breaker. The reason that I do not think it is the contacts or the caps is that he stated that the breaker did not blow.
Merle, when it runs for a second then stops, does the motor sit there and hum or make no noise, Also, the breaker does not trip, correct?
Can you try these and see what happens?
Turn it on
--does the motor spin for a second?
--if not, does it hum loudly?/does the breaker trip?
--if so, if you turn off the switch and immediately turn it back on, does it repeat? if not, what does it do. Hum, blow breaker, nothing?
With it off and unplugged for safety, does the motor and blade turn easily by hand? If not, then maybe something is binding.
I Had the same thing happen on a Jet table saw motor. It was the thermal overload switch (round re-set switch on the motor). Jet walked me through testing, all you have to do is bypass the reset switch by disconnecting the two wires that go into it and twist them together w/ a wire nut. Turn the saw on....if it starts up normally, the reset/thermal overload switch is bad.
The tech rep from Jet said they normally fail if there is a lot of strain on the circuit, i.e. running the saw off of an extension cord that is too long or too small a gauge or plugging it into an outlet where the wire is too small to handle the amp draw at start up.
I switched mine out and quite running it off a 50' extension cord and haven't had any problems since!
I spoke with Powermatic Tech Support this afternoon and Russ diagnosed the issue as a bad coil in the switch. Since there wasn't any hum and the blade turned freely he had me press the start button and again the saw tried to start but stopped immediately. Then he had me press the contact in and hold it in with a pencil and the saw started and ran normally. I now have a new switch on its way to me and it should be here Friday.
There are 2 bits of good news: the inside of the saw is now cleaner than it has been since the day I got it and I didn't remove the motor to take it to get serviced. It would have been a bear of a job getting the motor off and back on again.
I greatly appreciate everyone's suggestions and attempts to help.
I received the new motor starter and installed it today. Works like a champ!
Once I got the old one out where I could look at it I discovered the problem. The switch is in two sections and the bottom section has 3 prongs that plug into the top section. One of those prongs along with its contact had fried. I asked the Powermatic tech about that and didn't get a good answer as to why that happened. He stated that it's electronics and there may have been a power surge. Does this seem reasonable/likely? Any suggestions on how to avoid/prevent this from happening in the future?
A power surge wouldn't do what you describe unless it was bad enough to take out most of the appliances in your house. What probably happened is that the screw that fastened the two contacts together came loose, allowing the components to arc when under load. The heat from an arcing contact will usually cause the plastics around it to dry out and fail, resulting in the pieces you describe. This could have been a case of something working loose or something that wasn't tightened correctly at the factory. I have seen this condition many times while working as an electrical contractor and an electrician in a factory.
The magnetic armature in your motor starter (relay) moves about a half inch every time the motor is started or stopped. It moves ON with a POP at about a thousand miles per hour. When it reaches its stationary ON position, it stops its 1000 mph trip. The starter, if not attached properly, will jerk. It stops with either gravity or springs. This up/down movement (vibration) will gradually loosen the tightest connections!
The plant I worked in did a thermal study (infrared camera picture of every terminal) yearly. It would take three days to examine inside all the panels. He never failed to earn his keep. He would find those connections that we could not just tighten without shutting down entire assembly lines. Connections on starters should be tightened at least yearly.
