Craftsman drill press belts
Gary Smyth
>I have two Craftsman 15 1/2 inch floor variable speed drill presses. I thought that they were the same (except for the color and name plates) but they are not. One has a drive belt that is 1/8" and the other 1/4". The model numbers are 113.213780 and 113.21370. The parts manual does not say the size of the belts. Anyone know where I can get replacement belts? Sears says that the drill presses are too old for parts. Also, I don't need Sears parts if other belts are avaialble from somewhere else. I thought that this would be easy but thus far all I keep hearing is to forget the belt and change the pulleys--jeez, all I need is a belt.
Re: Craftsman drill press belts
Jim Shaver
>I bought link belts to replace mine, they have them at Lee Valley ;)
Link Belts!!!
>You can get the red Fenner drives and pay more or use the green generics that Harbor Freight sells for less. Fenners are a bit quieter.
You make the belt to match whatever length you need. I run them on most of my power tools.
Carol Reed
>www.beltsforanything.com
Re: Belt sources
Ben Ragusa, S. Jersey
>If you have not yet inquired at your local hardware store (Ace, TruValue, etc), you might want to consider them. Mine stocks a fair number of sizes, and if you have the old belts, they can measure them for you and provide the standard specs, allowing you to more easily search other local sources, ie auto parts stores, etc. Although I like and use link belts, sometimes a regular belt will do, and at a much lower cost. Last time I bought a belt from my local harware store, the cost was less than five bucks. Plus, I like to support them whenever I can. I'd hate to lose a good resource.
Link belt -- did I miss something?
Gary Smyth
>The belts on these drill presses are 1/8" wide and 1/4" wide. The link belts I see in catalogs are flat 3/8" to 1/2" wide. Wider belts will not fit the v grooves of the pulley.
Larry in NW Ohio
>Gary I ran into this 5 years ago. I have the same drill press, I really like it for the price I paid for it. The only thing I don`t like about it it it didn`t have a crank up table or a reverse on the motor, which I put on a couple of years ago. About the belt, if you haven`t found on yet, I think I bought them, I bought two, at a bearing place. The number on it is a Goodyear #, it`s 5MR1143. I hope this helps. You may also try Ebay. Good Luck Larry
No, I missed something
>You can get 1/4" Fenners, I think, but 1/8" you'll be s.o.l.
Been that for a looong time
Gary Smyth
Re: Been that for a looong time
>I checked Fenner's site and they do have a 5/16" "ground round" belt for small spindles. No 1/8" stuff however. Sorry.
Larry in NW Ohio
>Gary What happened to your old 1/8" belt, did it tear? If you need one , I could give you my old one till you find one. Or I could go to that place and see if I could get one for you if you cann`t find it. Larry
Larry
Gary Smyth
>It's still going, but fraying. I thought I would do some preventative maintenance after I discovered that the other belt in the other (not the same) drill press (what I thought would be my backup) is different than the 1/8". No need to loan me yours. I'm grateful though for your kind offer. Others have given me some places to look and I've emailed their suggested companies to find out what they have. I expect to hear back early next week. Thanks again, most kind!
Re: Larry
Dan Donaldson
>Let us know what you find. I believe that I may have that same drill press.
Re: Larry
Larry in NW Ohio
>Dan It may be a couple of weeks or more before I get over to that area again, but I`ll remember to go. You mmay try around you if you have a bearing place. Just take the Goodyear # I posted and they should be able to help some. Larry
