preferred wood for spatula
Jim Fontenot
>Is there a preferred wood for a spatula that will be used in a hot skillet for de-glazing? Do certain woods stand up to the heat better than others? Which causes most wear at the edge, heat or abrasion?
Jim Fontenot
beech
Bill Tindall
>I made some from beech and they have done well for many years. I used them as you described. I expect maple would also be good.
Re: beech
Jim Fontenot
>Thanks Bill. I've used maple and osage orange and modified a couple of beech but never used beech from rough stock. Although I assumed beech might be the best I never had any at hand when the mood came up to make cookware. Also, I loved yesterday's post.
Jim
Re: preferred wood for spatula
Robin Corell in Atascadero CA
>I make spatulas out of all kinds of woods. It is an on going project of mine.I mill all my own wood and when I get a species I am not familiar with I mill a branch on my bandsaw and dry the small boards in the microwave. This gives me an idea of how much degrade to expect and as a side benifit I can bend the hot pieces and get an idea of how suitable that wood is for steam bending. Awhile back I started making spatulas out of these sampls as a way to use the little blards but also to lean more about how the woods wear.
so here is a short list of a few woods:
Siberian elm- bends nicely wears well and holds up to the heat mederately well. Stands up to washing without getting fuzzy
Olive- dosen't bend very well but wears exceptionaly well
Acacia- bends well and wears very well, my current favorite cooking tool is made out of acacia. I gave one to a friend and it gets run through their dishwasher regulaly and other than having turned black it looks fine.
Mullberry- bends moderately well, need to raise the grain repeatedly before using.
Walnut- you can never co wrong with walnut.
Re: beech
Bruce, a MN Galoot
>I've used maple, cherry and walnut. The maple and cherry work better than the walnut, whose grain never seems to settle down - it constantly fuzzes.
Charles Yawn
>Jim, the spatulas I have made with cherry seemed to be holding up quite well.
Charles
Second vote for cherry
Steven Antonucci
>I've made a few that have done very well. I soak them in mineral oil maybe once a year, and they get hand washed. Use them daily/weekly...
Going out on a limb (or is it stalk?) - bamboo
>I don't have any spatulas of bamboo. I do have a number of stir fry spoons and other spoons that are made of bamboo. They work quite well in the hot skillet. My spatulas are either steel or silicon.
Re: Cypress
John b
>We have one that is at least 25yr. old. It did make it through the dishwasher a few times and still going strong. I like it so much that i made a bunch for x-mas presents a few years ago. The only one problem that we had was when my sons dog thought it was a doggie toy. My son begged for a new one (pun intended).
Thank you
Jim Fontenot
>Thanks Bill, Bruce, Robin, Charles, Steven John, and JL for your prompt replies. Good in formation from all and thank you Robin for the in depth info. Bamboo? Cut up some flooring material? Just might try that.
Jim
bamboo
>JL, do you need some bamboo to play with? A friend nearby has a stand on his 'lower 40' and I've cut a few stocks for odds and ends.
No, thanks
>I've got enough spoons and spatulas. The only other thing I use it for is pinning pieces together. I use the skewers from the grocery store for that.
