Carved Coffee Table II-Part 2 Carving legs etc *LINK*
Alan Young
>Earlier this week I posted a series of pictures and descriptions of the joinery of a coffee table. (See Link below).
Today I have a set of pictures showing the shaping and carving of the legs and apron sections. Let's look at the leg profile and design pattern from the first table
The profile is a generously shaped cabriolet form.
The carved design is an acanthus leaf descending from a flowered shell figure. The leg profile narrows as the foot ends in a modified French Toe- a small carved scroll on "point"
The carving's on the legs and aprons for the new table will will be different.
A Fleur de lis element, a descending diamond and "C" scrolls will be implemented on this table.
The legs are still in fairly rough form
Now I'll shape the legs through the use of a spokeshave and various carving gouges, and files
I carved the Fleure de lis elements separately. I drew the design then cut the lines into the wood with various gouges.
From there it's a matter of removing the background till the element is "raised
Once each piece is defined I cut it from the stock and begin another.
Each element gets glued to the top of a leg. I'll refine the carving further once the piece has set.
Next I'll start carving the apron sections.
The end and side sections of the apron each have a descending block.
The profile of these sections is transferred to smaller pieces that are cut out and glued to the apron. From there the surface is filed and carved.
The design for the end apron sections has a repeat of the descending diamond in the center block.
The side apron sections will have the descending diamond in the center block with "C" scrolls on either side.
A simple scroll bead detail runs from the center block around the apron ending in another scroll where the leg joins the apron.
It will probably be some time before the next set of pictures as I�ll continue the long process of refining the carved elements.
Alan
PART 1
And the Red Wing sweat top is too...
