We value your privacy.
>Hello, I am looking for dimensions of a "part" on a Rockwell Sonicrafter. This tool is kind of like a Fein Multimaster, seems like everyone is making one now. If someone has a micrometer or other accurate way of measuring... Could you tell me the dimensions across the flats of the hexagon (blade area) ? Feel free to email me or post here. Thanks a lot, Larry
>Thank you very much - I appreciate it a lot. Reason I ask is for making some adapters, to use multiple brand blades on 1 tool. It has already been done for the Fein, whose blades are very expensive. I own a Fein, and the cost of the blades and the constant loosening while using was reason enough to develop an adapter for it, now the Rockwell. Thanks for the responses - Larry
>I was impressed with the solid feel of the Rockwell but to be honest the reason I choose it over the others it that for $200 it included both tungston carbide blades, a wood blade, a wood/ metal combo blade, large and small sanding pads with a bunch of sandpaper, the scraper blade and a couple of felt pollishing pads. I didn't realize what a vaulue this was untill I needed to replace the wood/metal combo blade and it cost $20.
I have since been resharpening the blades with a diamond cup wheel in a fordom, But I think a cut off wheel in a dremel would do the job just as well. The baldes are not impulse hardened so I should be able to sharpen them down to nubs. I don't know how they will perform once I grind past the set that he wavy edge provides. If I need to I can add it back in with a ball pean hammer.
I imidiatley thought the blade chucking method was a potential for failure. If the sharp corners of the hex head become rounded the tool will become worthless. For that reason I have paid close attention to properly mounting the blades and tightening them. so far I have not had any problems and I have really put mine through the ringer. The only weakness I have found is that sheetrock dust can jam the switch. It works prperly adter a good cleaning but it was a suprise that that is its achillies heel.
>Mine is a variable speed model# RK5102K. From looking at their web site there appears to be a non variable speed unit availabe but They all look the same and I would guess that they all use the same blade mount system because all the accesories fit all models.
