Re: Harbor Freight air compressor
>Couple of observations, Joe.
1st, you need to be mindfull that this thing will require a 20amp circuit.
2nd, plan on using synthetic compressor oil, most big-boxes carry the stuff (Ingersol "Select" or similar) in their compressor section. Two reasons: a) it doesn't carbonize like petroleum oil does, so it keeps the valves and piston rings cleaner; b) it doesn't vaporize as easily and will reduce oil carry-over.
3rd, speaking of oil carry-over, you're going to need an oil removal filter to prevent getting oil in the air stream and on anything you spray. Assuming you'll keep the unit "mobile", you'll need to mount this on the compressor somehow, between the regulator and the hose to keep oil mist out of the air hose. Do this before you even run the unit because once you get oil in your air hose, it will contaminate anything down stream like spray guns, finishes, and wood.
4th, be prepared for some noise. These small direct-drive units, oil or oil-free, are much louder that their belt-driven siblings.
Lastly, you do know this ain't the deal of the century and this ain't a quality tool that you'll pass on to your grandchildren, right? Light use and inflate a tire or two it should do okay. Drop it and you'll go buy another one.
