A55 Smoothing Plane
Shop vacs
Shop vacs
Shop vacs
Doug Ridley
>I just emptied my shop vac and took the pleated filter out and blew about 95% of the dust out and it got me to thinking. (always dangerous). How long do you keep and re-use your filter? Do you buy a new one ever so often or just keep the old one as long as it still sucks good? I have been using the same one for 5 or 6 years but it seems okay. Another question- do you prefer the pleated filter or a bag? Inquiring minds want to know.
Doug
Re: Shop vacs
Re: Shop vacs
doug f, san clemente, ca
>I've been using my Fein Turbo III for about 7 years. I take the bag filter out each time I dump it and either blow it out with compressed air or beat the dust out of it with a few whacks. Suction is fine and it still seems to get all the fine dust.
If it ain't broke, don't fix it!
Now, go make sawdust.
Doug
Re: Shop vacs
Re: Shop vacs
Larry in NW Ohio
>I have a Craftsman and it`s probably 15 years old and the filter is the original. I have new ones, I bought them on sale, but the old one is still good, it doesn`t let dust blow out and it still seals good, as Doug said if it ain`t broke don`t fix it. Larry
Re: Shop vacs
Re: Shop vacs
Doug Ridley
>That's what I've been doing but I just wondered about others. Also do you like the pleated filter or a cloth bag? What about a cloth bag over the pleated filter? I have seen that done. Just wondering.
Re: Shop vacs
Re: Shop vacs
gary peterson
>I have a rigid with the pleated filter. I use it for my router table and band saw. Seems to get th e fine dust just fine. When I clean it, its put into a large plastic garbage bag, bounced onto the floor couple times and then, pardon the pun, when the dust settles I take it out and flip the pleats to get rid of any left over dust.
I used to run a craftsman and put an old t-shirt around the filter which was made of foam. That helped.
Re: Shop vacs
Re: Shop vacs
steve mackay
>Being cheap as I am, I use the filters like jeans. When they fall apart (or off) I'll change 'em. When the bottom rubber ring breaks I'll keep useing it as long as the bottom plate holds the filter so there isn't a gap in the pleats. When BOTH rubber rings go, its time. My vac runs my entire DC system (small shop w/ four machines) and I get eight plus years out of a vac. Pretty good considering the amount it runs. Probably put in a new filter every couple years. For me it seems filters are like sanding belts. If you clean them before material gets really impacted (or burned) into it, the longer they last.
Re: Shop vacs
Re: Shop vacs
Brian
>I also use a Ridgid with the pleated filter but I also recently added a Dust Deputy and what a difference that made! I've emptied the Deputy about 3 times now and the pleated filter is still clean.
But to answer the original question, I've always just taken out the filter and whacked it out in the street to remove the caked on dust. Been using the original filter for about 5-6 years now.
Re: Shop vacs
Re: Shop vacs
Alan in Little Washington (NC)
>I second adding the mini-cyclone.
It extends the life of the filter and time between cleaning. It is much easier to dump the bucket and hardly ever need to empty the vac tub. You can use it with any vac and achieve results better (and for less $) than the high dollar vacs plus (to quote Mr. Dyson), you don't lose suction. There are pics of mobile versions of it on the web. Here is pic of my fixed installation mini which is a ClearVue (currently unavailable), but Oneida has a similar unit starting at $59 w/o bucket):
Re: Shop vacs
Re: Shop vacs
Jim Dillon
>Doug,
I had a well-loved, but now gone, WAP vac that had a "hair-net" around the pleated filter and that seemed to work just fine. The net seemed like a non-woven fabric with an elastic to hold the net to the round pleated filter. Regarding the life of pleated filters, I never have replace them and just shake, then blow with compressed air and they seem good as new. Maybe if someone was collecting drywall dust etc. 24/7, replacement might be necessary. Otherwise, they should last a long time with minimal maintenance. At least that has been my experience.
Jim
Re: Shop vacs
Re: Shop vacs
Larry in NW Ohio
>I do have a naked pleated filter, one with a paper prefilteron it and one with a cloth bag on it. I don`t think it makes a difference. I`m thinking about getting a dust deputy. I`m going to order one when we get back from Kansas City this weekend to see our new granddaughter. Larry
Re: Shop vacs
Dust Deputy
Joe Pack
>Buy a dust deputy and never empty your vac or change a filter again, ever! :D Well, maybe not "ever" but not very darned often. I use my 16 gallon Rigid with the Dust Deputy in line on my radial arm saw w/collector box and on my drill press. I have emptied the bucket on the Dust Deputy 4 times since I got it (about 2/3 full each time). In all that time, I have collected less than a double handful of dust in the tub of the Rigid vac, and the filter looks like it is brand new. :O The Dust Deputy is the best contraption I have added to my shop in years. ;)
I have the original metal Dust Deputy w/the metal Oneida bucket. Mileage on the new plastic Dust Deputy may vary....but I don't think so. 8) (Sorry, love the smilies and just had to play with them! :b )
Re: Shop vacs
Re: Shop vacs
Keith Newton----Little Rock, Arkansas
>I use the pleated a long time, but do replace them when it looks too impregnated with the really fine crud.
Of course the pleated just offers lots more surface area than a smooth cylinder would.
When I empty the containers, I then catch my breath, before quickly bang the filter inside the container like the clapper of a bell. This jars the dust out of the folds pretty good. I can then dump the container and run before catching my next breath.
When it needs a deeper cleaning, I have found that pretending the filter is a bowling ball, I give it a trip down the parking lot. The spinning centrifugal force and vibration from the asphalt will really get the finer stuff like sheet-rock dust.
I just don't like the cloud of fine dust when blowing out the filter with compressed air, so it is not too bad after doing the above.
Re: Shop vacs
Re: Shop vacs
Tony - Memphis
>Hmmm, never thought about it either. I have a pleated filter (something stream?) on my ~14 year old SHopVac. I've never changed it. I clean it with a stick that fits in betwen the pleats and by beating it. Never washed it with water. Seems to work real good still. I mainly use it to clean off tools and the floor. It was my dust collector unit for several years. I tried the panty hose trick over it to make it easier to clean. That worked ok, but it was almost more trouble than it was worth. Maybe my wife isn't fat enough! The hose were really tight and I tore them a lot.
Tony
Re: Shop vacs
Re: Shop vacs
Bill White
>I have 2 Ridgid vacs with the higher quality filters. I just keep blowin' 'em clean. They are used for general small tool DC and shop clean up. The big DC takes care of the major stuff. No need to change 'em if they're still workin'.
Bill
