We value your privacy.
>This small piece, pivots on my table saw fence (craftsman, very old). I need to glue it back together. JB Weld has worked for awhile, but now it will not take. Any good glue suggestions? I believe the material is cast aluminum. I can't find the replacement part (64208) anywhere on line, and am looking for a replacement fence (113 29940), prently. Thanks in advance,
>If you want to try the aluminum brazing rod like is shown in Stuart's post, send me an e-mail with your address. I'll send you a piece of rod. I bought some at a sports show a few years back for repair on my aluminum boat. Never used it, but the demo, and the video in Stuart's post, made it look easy. I'll send you a copy of the instruction sheet, too.
>Call Loctite. One of the students that I was working with this summer was gluing aluminum. He was having trouble so he called Loctite and they told him exactly what to use and it worked great. I don't remember what it was.
>One of the problems with a repair like yours is that you need to clean off the old stuff. If the exact length of the broken off part matters, a welded repair that builds up metal or starting from scratch may be necessary.
It looks like a fairly simple part. Have you considered looking for a piece of metal* at your local scrap yard and hacksawing/filing a replacement? It should be possible to do that in an afternoon, and wind up with a stronger component than Sears ever made.
*aluminum probably easiest, brass nice but hard to find a chunk that big and expensive too, steel would be more work but might be strongest; if you happened on a chunk of good cast iron, that might be ideal.
Re: Be aware that you'll need to clean off the JBW
>>...hacksawing/filing a replacement?
A local hobbyist with machine tools might make something for cheap or trade. But from the appearance it might not take much more than a drill press and a tap and some kind of saw. I like making things out of mild steel since it can be cut easily with a reciprocating saw and a metal-cutting blade (I like the bi-metal The Torch blades by Milwaukee, widely available). Be even easier with a welder.
>Glue won't work for long. It WILL fail again. I know there are JB Weld etc enthuiasts who are dedicated to their repair of choice but they are projecting a few successes to cover all circumstances ("Hey, if it fixed an ashtray, it will fx a 747 wing"). I've repaired countless parts like that and all epoxy repairs do for broken castings is make them hard to weld repair.
Trust me, if you want a reliable repair of a broken aluminum casting find a good welding shop and have them weld it up. If the welder is up to snuff he can weld repair that broken part so that it looks like it had never been repaired - that is, if you don't mind paying extra for the cosmetic treatment.
This leads me to my usual rant: A home shop owner cannot cover all the bases. He needs to recruit a network of contacts skilled at different things and trade favors with them. I've never seen a woodworker that didn't need a little machine work or welding in the course of a year. Or a machinist that didn't need a box or cabinet to store delicate tools in. Or a welder that didn't need a supply of wood wedges and clamp pads for fixturing parts for tacking.
>I have used Hysol EA 9430 to glue aluminum tubing to epoxy/fiberglass molds. The glue is awsome but read the info on the link. The mix ratios will mean you will have to use a good scale to measue and one of the components is the viscosity of water and the other is the viscosity of cold peanut butter. it is not easy to mix! You will need to clean the two parts very vell and I would even recomend grinding to mating surfaces imidiately befoe applying the glue.
That all said I would probably opt to fabricate a new bracket. Aluminum cuts easily on a bandsaw with a standard wood blade.
>Hi, Bob - I can't tell the size of the piece that broke, but I would go down to my local scrap metal place and find a chunk of aluminum that was big enough to make a new piece from. The piece doesn't look very complicated and aluminum is very easy to work. You can easily cut it on a bandsaw and I have done a lot of sheet aluminum on my tablesaw. I picked up a blade from Sears years ago that cuts it great. A little wax on the teeth reduces the build-up when cutting. I think you could make a new piece easier than you could fix the old one.
