THE WOODRAT IS BACK!
Shop Heater Questions
Barry
>I have an old 220 volt Arvin Heater that I use to heat my shop. From time to time, sanding dust gets into the heater and clogs the motor. When this happens, I have to break down the heater, clean out all of the sanding dust and re-lube the motor bushings. The last time I did this, I noticed the motor shaft is showing some wear.
I do not believe that this heater is manufactured any more. It has a fan powered by a squirrel-cage motor. Does anyone know where I could get a replacement motor? Because of the heat, the motor is quite sensitive to types of lubricant. Many just turn gummy after a few days. Currently, I am using a combination of Tetra synthetic gun grease/oil and graphite, which seems to work fairly well so far.
Re: Shop Heater Questions
Galen Vetterick
>Barry
Grainger has open air over HVAC small motors but many do not have standard frames so you might have to adapt. Most are set up so the cool air is pulled in over the motor by the fan so they do not run hot.
These little motors have oil impregnated sintered bronze bearing and normally when the motor runs the oil comes to the surface and produces the film lubricant and when the motor is not running it is reabsorbed. Some have oil slots with felt that you can relube with a Very Small Amount of Thin Machine Oil. If you use a grease it will plug the pours and not provide the proper oil film. Any grease would only add to the dust collecting on the shaft and cause wear.
I've soaked old sleeve bearings in solvent and used a gun cleaning brush run through them and then used my own pressure system to try to force the thin lube into the pours if I jsut was trying to extend the life of an old motor.
I seem to try to extend the life of things rather than buy new as that is the way I grew up, as our family had little money since my dad died when I was 8.
Gerry In North Surrey
>If you want to continue to lube the shaft I'd suggest steam oil. No, I'm not kidding, it's used to lube the piston rods and cylinders of steam locos. It's formulated to mix with water/steam and to be resistant to high temps (a superheated boiler can produce 600F steam). If you're anywhere near a live steamers group they should be able to help you out.
Gerry, who's a live steam nut and plays trains as often as possible.
Barry
>I'm not opposed to being frugal myself, but this seems to be my only option at the moment. I don't think these heaters are still made, so I can't replace it. It's way too old for replacement parts.......unless I can adapt a generic motor for this application. What would the rpm's be on a motor like this? There seems to be a range from 1100 to 3000+ rpm's. There are more offerings in the 3000 range, so I'm inclined to think that may be what I need. I would prefer to just replace the motor rather than keeping this one on life support. Any advice is appreciated. Thanks for the response.
del schisler
>their is one on ebay bid so far $0.99 here is a pic may not be the one but here it is
Barry
>OK. Thanks. I forgot to mention that my heater is a 220 volt, 4800 watt. It has a plug like a clothes dryer on it. This one is probably a little small for my space.
Re: Shop Heater Questions *LINK*
Galen Vetterick
>Barry
Probably best to get what information you can right off the motor. I just assumed it was a direct fan mount but you did not say. Again most direct fan mounted motor will be 1750 or less rpm.
When you have info I would give Grainger a call and see what they have out of the long list of motors they list. Some are direct OEM motors.
Grainger
Dale Warder
>Northern Tools has a 4000 watt, 220v, heater with the plug you describe. It is currently on sale. I use one of these to heat my shop.
Larry in NW Ohio
>Barry You might try surpluscenter.com, they have a few motors. They are nice to deal with, you might get lucky and find one cheap. Larry :)
