water based poly
water based poly
water based poly
Al
>I'm building some kitchen cabinets and am looking for a good water based poly for the drawers (maple). I tried the Hydrocote Resisthane Plus Precatalyzed Lacquer based on a review in one of the mags and found it didn't brush all that well. In addition, no one around here carries it so I have to mail order it. I'd rather use something I can buy locally, which is pretty much limited to some of the more common brands that you'd see at Home Depot or Lowes. Does anyone have any experience with any that brush well and would look good on maple? Thanks!
Re: water based poly
Grant Wilkinson
>I've had good results with Varethane Diamond Wood Finish. I've used satin and semi-gloss and like them both. My bedroom furniture has been done for 7 years and there has been no colour change or wear at all. You can brush it or spray with HVLP. I've done both.
warning...
Bill Tindall
>There are two ways to formulate a urethane varnish, be it water based or solvent. The most common way results in a finish that will trun yellow over time. This yellowing can be attractive on walnut, cherry and staned oak, but look gross on a "white" wood like maple or ash.
Presuming the maple is to be finished natural you need a nonyellowing finish. Possibilities include water based acrylic, "aliphatic resin urethane", or a butyrate lacquer (solvent based).
Another problem with many water based clear finishes is that they don't have a bright luster. The distracting bluish cast they used to have is less common that it used to be.
Call the tech service department at Target Coatings and ask for a recommendation.
We recently had a presentation by General Finishes. They have some very nice water based porducts, but their urethane definitly yellows.
Clint Searl, at the base of Haycock Mountain
>Also, Varathane water borne floor finish. It contains aluminum oxide for extra hardness.
Clint
bill sams
>http://www.grahampaint.com/product_ceramithane.htm
http://www.grahampaint.com/howto_wood.htm
the two links above describe Muralo/Graham Ceramithane. I usually buy from Highland hardware in gallons, price $62. p/gal. I have used it on many projects, brushes easily, goes on clear. As all wb goes, it does not bring out the colors, so for my purposes I first watco oil, then diluted sealcoat , then ceramithane two coats. Very durable.
Glenn Madsen---in SF Bay Area
>The Varathane I used was no treat. I brushed, but have not purchased another quart...
Lee Schierer McKean, PA
>This vanity is finished with Varathane Diamond floor finish. I really liked the way it brushed on. I will use it again on larger projects. Unfortunately they only sell it in gallon size. It has held up in a bathroom for 3 years so far.
General HP poly
Robin Corell in Atascadero CA
>I have been using General's hp Poly for a couple of years now and love the results. I use a Raphail #290 brush which is similar to a davinci cosmotop. I have found the expensive brushes to be well worth the money as they leave a smoother surface with fewer bubbles and load up nicely. I apply 2 coats before I do any sanding and then it is just a light swipe with 220 . another coat or two and then I buff with steel wool. Once dry it will sand and buff out like nitrocelulose. It is a bit soft for a couple of weeks but once it is cured it is great for table tops and chairs. It is available in satin, simi and gloss. I have only used the gloss.
I almost for got it has a UV inhibiter and costs about $60/gal.
Al
>Thanks for the great responses. I think I'll give the Diamond Varathane a try since it is available locally.
