Moving Wood and the Pains Attendant Thereunto
John McGaw
>Well, on Tuesday I finally got around to sawing up the last remaining hickory log in the side yard. Originally I had great plans to have the two trees sawn into lumber but never found a way to move them to a sawmill or to move a sawmill to them. That meant that three of the four log sections were relegated to firewood duty. But I left one nine-foot-long 20-inch-wide log behind and I managed to get it propped up so it was almost entirely off the ground (not easy since I estimated that that piece weighed between 1250-1500 pounds).
I finally felt energetic enough and the weather was good enough to allow me to tackle the sawing task. I had bought a rip-tooth loop from Bailey's and put in on the old Stihl 029 Super and attacked. After about three hours I had two slabs taken from the center of the log eight-feet long and anywhere from 3-5 inches thick -- freehand cutting in a clumsy position kept me from being more accurate. Of course now I'm left with an aching back from the effort of getting the two 400-pounds slabs up off the ground and there is still a major problem in that moving them to the garage where I had planned to dry them for a few years is a near-impossible task for one person with no special equipment. But at least they didn't go straight to the mountain of firewood that needs to be split.
Re: Moving Wood and the Pains Attendant Thereunto
>How about using sections of Schedule 40PVC pipe to roll those slabs to the garage? I've moved machines, furnaces and all sorts of stuff on pipes.
>Ellis hit exactly what I did only I used steel conduit, I guess because I had it. I've move some very large logs this way. My good friend Brad Sells carves extremely large logs into incredible pieces. Brad just cuts a limb off the tree. Pries one end of the log up and puts the limb under it. then he uses an electric winch to pull it onto a trailer. They just keep putting pieces of limb under. the winch is actually strong enough to tug it on but it tears up the yard and may damage the ramp to the trailer. The limb sections prevent this and take a huge load off the winch.
Larry in NW Ohio
>John This is going to sound strange, but could you take a truck and a rope or chain and pull it as close to the garage as you can, you could maybe even pull right in the garage with the truck and back out right over the slab as long as you can clear it. Then maybe hook it to the front while it is under the truck and chain the front of the slab to the underneth the front of the truck as tight as you can and drag it farther in. I did this once and worked pretty well. Larry
How I do it...
Grant in Iowa
>My approach:
I have moved several logs in the 2000 lb+ range in the past 6 or so years. Here are some of the ways I move them:
A long cable, snatch block, and a vehicle that can pull to move logs out of a hard to reach area such as a ravine, or steep back yard. I bought a 100' long 5/16" cable at a local farm supply store. I added a thimble and chain hook to each end. I bought a snatch block or pulley block to allow direction changes and the ability to double the pull as needed.
The cable can also be used to roll logs onto a trailer or up an incline. First, secure one end of the cable to the trailer or a secure object like a tree (Use a strap to protect living trees). Then run the other end UNDER the log, doubling it back over the top of the log to a pulling device. When the cable is pulled, the log will roll easily towards the secure end. I use this technique and a ramp set on the side of the rear of my trailer to get the leading end of a log onto the back of the trailer. From there, it can be winched onto the trailer rather easily.
When I had to take logs out of a friends hilly wooded back yard, I made a skid of salvaged 2x8" and 2x10" lumber and carriage bolts. I added steel rings and a short length of chain. The leading edge of the skid was beveled at the miter saw before assembly. The log is rolled onto the skid with a peavey and secured with ratcheting cargo straps. I position the log so the front of the log is barely overhanging the front of the skid. This allows the skid to float over the ground without digging in much. I pull the assembly with a pick up and the above cable . It pulls much easier than one would think. Winter time and snow on the ground makes it even easier to move so long as you have a dry surface to pull from. Short of that, a hand or electric winch could also move the skid and log. The largest oak log pictured below is 28" in diameter and 10+ feet long (the skid is 5.5' long)
If you wanted to get really serious and low impact, you could move a log with a log arch, which is a wheeled arch designed to move logs without dragging them. Check out www.Baileys.com for more info on the commercial models and to get an idea on how one might be made.
I have also bought a steel decked small car trailer that I use to haul logs and also my small tractor/ loader. A friend of mine and I have made a mount for the stake pockets that allows the attachment of a hand winch to ease loading logs onto the trailer.
In summary, if you study up on the web about moving logs, you'll find many solutions both manual and automated.
When the weather improves, I may just take an afternoon and take some photos of do it yourself log moving techniques.
Of course, whenever you are dealing with pulling heavy loads, you must take appropriate precautions and safety measures. If you aren't sure of the hazards and weights involved, STOP and do the math. Make sure all components in a pulling system can handle the loads involved. When buying cable or other components, read the label for safe working loads on the spool and packaging and make notes for later reference.
I have found that while I have invested (spent?) a moderate sum of money on the hardware to move logs, the payoff is huge when it comes to a nearly unlimited supply of low cost lumber in the shop. Besides, it is good exercise, good for the environment, and helps local business' such as the mill operator and kiln owner. Another benefit is to be able to say "That piece of furniture was made from a tree that came down in the storm we had two years ago".
FWIW,
Grant in Iowa
Re: The skid photo...
Grant in Iowa
>Dunno what happened, but the skid photo didn't take for some reason the first time...
And a close-up of the skid... The base boards are 2x6"'s, and the crossmembers are 2x12"'s I think... It is about 28" wide and maybe 5 or six feet long. Two short lengths of 2x6 make good "ramps" to ease rolling a log onto the thing. I usually place something wedge shaped such that the log will stop rolling once it is about centered on the skid.
More notes on skidding and cable (LONG)
Grant in Iowa
>The amount of weight you can move with a skid is quite a bit more than you might expect.
I got the idea for a skid from our family farm. We used to use a skid 8 feet wide and 16 feet long to haul baled hay in from the fields. While not quite as efficent as a hayrack to pull, it was cheaper to build and maintain, easier to step on and off while moving, and you could pile the hay higher, because it was less likely to tip. The skid we used to haul hay was very similar in construction to the one I have made and pictured. Its one drawback was that you had to be careful on downgrades that were hay or grass, as it could have a tendency to slide into the back tires. Dad solved that issue by threading the chain through a length of pipe, then through the clevis hitch on the tractor, through another length of pipe and back to the skid. Another favorite use for it was hauling firewood from the woods to where it was split. We hauled LOTS of firewood on one load behind a farmall C tractor. Maybe 3 pickup loads worth up and down hills with no problems. No lifting at either end, and the ability to load large rounds with relative ease.
They don't tear up the ground as much as you'd expect, either. I moved several logs across a mowed lawn and the only damage was a few high spots in the yard that needed "planed" down anyway. I wouldn't go back and forth all day in one spot, but the damage is indeed minimal. The key to limiting damage is to load the skid rear heavy, or use a short chain as below.
In limited traction situations, you can shorten the chain up between the tractor/ truck and the skid. Once you begin to pull, the weight transfers somewhat to the tow vehicle and more traction is gained. Obviously, this action also transfers weight off of the skid and allows it to ride over uneven ground with greater ease.
You can use such a skid to move heavy items of all sorts. Landscape materials, giant lawn rocks, firewood, etc.
How much can you move with one? Depends on the tow method, the type of ground you will be traversing, and how balanced the load is. I have no problem moving 2000 lb logs on mine with my 1800lb compact tractor over gravel, grass, dirt. A good heavier duty garden tractor might be able to shift 800-1000 lbs on a short chain. I would expect a 4WD full sized pickup could move a 3-4000 lb log with a short chain without much difficulty. Again, you can move much more than you might expect. And there's no reason you can't use a long cable or series of chains to apply the towing force from a distance if the subject load is far off the road. Just be sure your tow cables, shackle equipment is up to the task.
For example, I'll hook on to the skid with 100' of cable, connect it to the tractor or truck and pull until I am out of clearance. Then I'll back up 50+ feet and double the cable back on itself. The two ends of the cable will then attach to the skid and a snatch block (permanently threaded onto my cable) will act as the hitch point for the truck... Then I can pull another fifty feet.
Say you have a load that is 70 feet off the road. and you want to drag it out at a right angle to that road. Connect one end of the cable to the loaded skid, attach the snatch block to a stout tree on the opposite side of the road (with someone watching for traffic) using a nylon sling strap, and then pull on the remaining end as you drive up the road. This allows you to drive along a road to apply the pulling force. In this way you can move a log out to a road while never leaving the road with your tow vehicle.
As always, before you pull, talk to everyone present and instruct them where to stand to be safe from the possibility of the cable or some other component snapping. Tow slowly in case your skid hits some obstruction like a tree or stump. Keep kids in the cab of the truck or leave them at home!
If you find that you can't tow the load on the skid using the cable, you can use the snatch block to double your pulling power: Connect the snatch block to the skid, connect one end of the cable to a stout tree as close as possible to the direction you will be pulling from, and the other end of the cable to the tow vehicle. You will need to pull twice as far with this arrangement, but you will also have nearly twice the pulling power. make sure your snatch block is rated for the load. A good snatch block can be $50-$70 and will have a bearing.
Anyway, this is a very versatile low cost method for retrieving logs and other heavy items. The 5/16" cable I have was about $70 with the two end hooks and six cable clamps (three per end for security). it is rated at 6000+ lbs. I added the snatch block for another $26 or so if memory serves.
Here's what the snatch block looks like:
The skid hardware was about $35. 4 heavy duty tie downs of the sort that could be bolted down, and a pile of 3/8" carriage bolts and nuts. I had the length of chain that I placed on one end of the skid. The skid weighs about 70 lbs at the size I made it, so it can be dragged back in the woods by one adult.
Regards,
Grant in Iowa
John McGaw
>Well, I no longer have a truck but I do have a Subaru and a 4X6 trailer and when (if?) it ever dries out I'm probably going to experiment. The maneuvering room is mighty tight in the side yard and the terrain going across the front yard from the driveway is a bit problematic but I figure that it can be done. If I drive forward from the driveway to the side yard towing the trailer I should be able to unhitch it and manually place it close to the wood facing the way back out. Then I should b able to get the car out and lined up with the trailer and re-hitch it. Backing this little short trailer is almost impossible even when there is a lot of room so I want to avoid it at all costs in this tight space. Then getting the planks onto the trailer should be a matter of dragging them onto the trailer with a come-along but since the trailer is super-low it shouldn't be that bad. After that a straight tow to the driveway and then back it up at least partially into the garage to unload and sticker the wood. Or so the theory goes. All of this depends on the rain stopping and the ground drying out at least a bit.
JKJ in East TN
>I haul a lot of logs and slabs with my tractor and flatbed truck or trailer. Just bought a bobcat to help around the sawmill too. I use the chain/cable rolling method grant described on logs too heavy to lift directly with the equipment. (This works best if the log is round!) It's surprising how beg a log can be rolled up an incline into a trailer or truck this way: I've pulled the cable with everything from a tractor to a come-along.
Where do you live? Maybe someone nearby can move it for you. A fellow woodturner might do it for fun; someone else might charge a few bucks depending on logistics.
A rental place might also have a pallet jack which might work if you are on flat pavement.
